Thread started 30 Sep 2011 (Friday) 02:46
Microadjust - What aperture?
snakeman55
Sep 30, 2011 02:46 |  #1
I'm trying to MA my 24L - it's a tad soft wide open. So should I do the MA at a wide aperture since that's where my concern lies, or is there some rule like you always microadjust at F/8 I don't know about?
Thanks,
-Adam
Wedding Photographers in Maryland (external link)
Gear
Edwin ­ Herdman
Joined Aug 2011
Sep 30, 2011 02:48 |  #2
Wide open is the standard advice, since DOF is thinnest there.
Do be cautious of focus shift with some lenses though - if it was still giving you trouble then you could try at your usual shooting aperture (if you have such a thing) but there isn't much sense in doing MA for a less precise setting (i.e. a wider aperture) otherwise.
Good luck!
snakeman55
Sep 30, 2011 04:04 |  #3
Thanks!
-Adam
Gear
yogestee
Sep 30, 2011 04:18 as a reply to  @ snakeman55's post |  #4
Is your lens just optically soft,,or is it misfocusing?
There is a difference.
Jurgen
snakeman55
Sep 30, 2011 04:35 |  #5
yogestee wrote in post #13186065 (external link)
It's missing focus. I'll lock focus on a subject's face, but the face will be soft and their chest will be sharp. That sort of thing. This is what MA fixes right?
-Adam
Gear
MikeJohn
Sep 30, 2011 06:01 |  #6
snakeman55 wrote in post #13186097 (external link)
Correct, microadjust only fixes front/back focusing issues not a soft focusing lens.
Sony RX100, Canon S90, 1DMKIV, 5D MKIII, 16-35 II, 24-105, 70-200 II, 100-400, 300 f2.8, 1.4x III, 580EXII
crn3371
Sep 30, 2011 08:37 |  #7
Aren't lenses, by default, wide open while achieving focus and only stop down at moment the shot is taken?
Daan37
Sep 30, 2011 08:40 |  #8
crn3371 wrote in post #13186677 (external link)
Yep. That's why you should always MA at wide open setting.
Canon + Elinchrom | www.daanbarnhoorn.nl (external link)
cristphoto
Sep 30, 2011 09:54 |  #9
You set the lens at maximum aperture and select a subject at least 50 times the focal length of the lens being adjusted. So for example a 100mm lens would bet set to focus at least 5000 mm away (50 x 100 = 5000mm). (I use the Spyder Lens Cal device which gives a nice target to perform micro-adjustment. There are various other brands available). Set up on a tripod as this test requires accuracy. Start with MA set at 0. Take three shots. After each shot manually focus the lens away from the selected focus to make the lens refocus on the second and third shots. Then set MA in camera to +5 and repeat. Then go to +10 and repeat and then +20. Then set to -5, -10 and -20 repeating as before. Take notes to be sure you know which shot was taken with their respective MA setting. I then download all the shots to Lightroom and see which setting looks best and set the camera appropriately. Once you see which setting looks best you can fine tune the MA in increments of 1 unit for absolute precision. Good luck.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
1,679 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is droneworx
779 guests, 158 members online
