Thread started 02 Oct 2011 (Sunday) 06:34
fast prime for indoor and portrait
eyalha
Joined Oct 2011
Oct 02, 2011 06:34 |  #1
I buying 2 new lenses, one will be an "always on my camera" type of lens probably the 24-105 f4 and I'm looking for something that I can use for low light situation mainly indoor and possibly portraits, so since the obvious solution is a prime
I'm asking you guys what lens do you think I should get? (50mm or less)
any thoughts by someone with first hand experience with any of the lenses in that range will be welcome
oh I should probably mention that I own the 17-40 f4 and the 70-200 f4 so I really need a lens with a large apreture
Any and all comments/suggestions will be gladly accepted
5D2, 24-70L F2.8, Sigma 85 F1.4, Sigma 50 F1.4, 70-200L F4 IS, 100-400 F4.5-5.6 II, 430EX II X 2, A few Pocketwizards
twoshadows
Liquid Nitrogen
Gallery: 52 photos
Best ofs: 19
Oct 02, 2011 06:42 |  #2
Welcome :) .
What camera?
xgender.net (external link) Miss Julia Grey (she/her/Miss)
The Chronochromagraph "how to" thread
eyalha
Joined Oct 2011
Oct 02, 2011 08:12 as a reply to  @ twoshadows's post |  #3
thanks
canon rebel T2I
waynethegiant
Oct 02, 2011 08:14 |  #4
Canon 35L if it isn't out of your budget. Or else Sigma 30mm f/1.4.. I always find 50 too long for 1.6 crops for indoor use..
Canon EOS 5D Mark II + BG-E6 Battery Grip
Sigma 50mm F1.4 EX DG HSM | Canon EF 17-40mm f/4L | Canon EF 35mm f/1.4L USM
AlienBee B800 | Canon Speedlite 580EX II
Tamrac 5586 Expedition 6x
eyalha
Joined Oct 2011
Oct 02, 2011 08:33 as a reply to  @ post 13194219 |  #5
The Canon 35L is definitely out of my buget but the Sigma sounds good although I'm a bit hesitant about buying a third party lens because I've never done it before and I heard some bad expereinces from other people
Is the Sigma better then the Canon 35 f2 beside the obvious apreture?
Sirrith
Gallery: 50 photos
Joined Nov 2010
Oct 02, 2011 08:57 |  #6
Sigma 30 is the one you want. Perfect lens for indoors (and out).
There are bad experiences out there for pretty much every single lens on the market. Does that mean you are now scared of buying new lenses altogether?
The canon 35 f2 and sigma 30 1.4 are pretty much on par in terms of IQ, but the sigma (obviously) goes to 1.4, has HSM, FTM, better build, comes with a hood (I think the 35 f2 has a screw on hood, which is bad, and in any case you have to buy it separately), longer warranty, and nicer bokeh (35 f2 can give jittery bokeh).
Unless your budget is really that tight, I'd spring for the sigma.
I also tried the canon 28 1.8 at a store when I was making the same decision, and decided there was no way I'd be happy with that instead of the sigma.
Finally, look at the amount of posts alone in the sample image threads, which show the sigma having over 3x more posts than the 28 1.8 and 35 f2 combined, which should tell you something about its popularity.
-Tom
artyH
Oct 02, 2011 10:03 |  #7
I have the Canon 35f2 and the Canon 50f1.4. At f2, they produce very similar images. I use my 35f2 more than my other lenses. It has a couple of weak spots. AF is accurate and fast, but not quite as fast as the 50f1.4 and nowhere near the speed of the 85f1.8. The lens is prone to flare if you shoot into the sun - I just avoid that. I am not bothered by the sound of the AF, but some people are. The Canon hood clips on, and it stays on the lens all the time - the combo is light and compact.
Inside and outside, it is my favorite lens. The 35f2 is light and sharp on my T2i.
twoshadows
Liquid Nitrogen
Gallery: 52 photos
Best ofs: 19
Oct 02, 2011 11:49 |  #8
If you plan on buying the Sigma 30, I would go to a B&M store and try it out first. They are known to have focus issues - some obvious, some not so - that I imagine are the result of Sigma having to reverse engineer Canon's AF protocol. Also be aware that the Sigma has a rather long MFD when compared to the Canon 28mm f/1.8. Also be aware that there is the possibility that you may buy the 30, have to send it in for calibration (everybody here seems to recommend it, but I don't agree), get it back not working properly and have no recourse since you would be past your return date. It's the chance one takes when going 3rd party...
Imo, the Canon - with its hood is about $40 more than the Sigma - is the better bet. It is slightly behind the Sigma in IQ, BUT has the best AF in its class. It also has a great (read: short) MFD, is built at least as well and more compact/lighter.
I have no experience with the 35 f/2, but it seems to me that it is the bang for the buck value of the 3 lenses.
DreDaze
Gallery: 49 photos
Oct 02, 2011 12:48 |  #9
i'd sell the 17-40L and pick up a 17-55IS instead of getting the 24-105L...or sell the 17-40L and get an UWA to pair with the 24-105L
having a 17-40L,24-105L, and 70-200L seems worse to me than a 10-22mm,24-105mm, 70-200mm, or just a 17-55/70-200mm combo
do you already have a flash for indoor use?
Andre or Dre
gear list
Instagram (external link)
SamuelYCWang
Oct 02, 2011 13:01 |  #10
I say 17-55 is more suitable for you. It's wide, it's fast, it has 3-stop IS, and unfortunately, it's cost as much as your 24-105L.
Canon 5D MK III
EF 17-40 f/4L USM
ER 50 f/1.2L USM
EF 24-70 7/2.8L II USM
EF 70-200 f/2.8L IS II USM
Sp1207
Joined Nov 2010
Oct 02, 2011 13:55 |  #11
Easy. Sell 17-40L and get a Sigma 17-50OS for ~50$ extra. Twice as fast, sharper, and has IS.
If you want faster still the Sigma 30 is it.
Gear
mjHession
Gallery: 6 photos
Oct 02, 2011 14:15 |  #12
I'd go for the 17-55 over the 24-105 for your zoom. Then add an 85 1.8 as a fast prime to compliment the zoom.
Primary Gear - M6 Mark II; Σ f/1.4 Trio (16, 30, 56) - Σ 150-600mm f/5 - 6.3 C
Sigma 1.4x & 2x
Full Gear List - Feedback
twoshadows
Liquid Nitrogen
Gallery: 52 photos
Best ofs: 19
Oct 02, 2011 14:45 |  #13
Sp1207 wrote in post #13195215 (external link)
It is? Why don't you have one? :)
DreDaze
Gallery: 49 photos
Oct 02, 2011 14:49 |  #14
twoshadows wrote in post #13195370 (external link)
because the sigma is just for 1.6 crop cameras? :D
Andre or Dre
gear list
eyalha
Joined Oct 2011
Oct 02, 2011 16:51 |  #15
The main reason that I don't want the 17-55 f2.8 is that my dad and I share most of our lenses and he is going FF so I rather buy something that is compatible with FF cameras
(same with the Sigma 30 f1.4) but another reason is that I like the reach of the 24-105 even though it's not the onventional range most want I think it's a better fit for me
I'm still contemplating the 28 F1.8 vs. 35 F2 any thoughts on the two of them
4,347 views & 0 likes for this thread, 15 members have posted to it.
1059 guests, 115 members online
