Thread started 04 Oct 2011 (Tuesday) 21:28
How do you do this?
HrcRacing
Oct 04, 2011 21:28 |  #1
If I knew what it was called I would have searched. :o
Can this be done with PSE 4?
Thank you.
http://www.joeybowman.​net/photos/1195361293_​37wV9-L.jpg (external link)
Robert
Canon 40D | Canon EOS Elan 7
smarti77
Oct 04, 2011 21:34 |  #2
I've seen it referred to as multiplicity. Lots of how to's available thru google..
I don't know anything about pse 4 but you will need layers and masking..
redbubble (external link) / flickr (external link) / Instagram (external link)
Merovius
Joined Jul 2011
Oct 04, 2011 21:46 |  #3
Here's a couple good threads, as well as a tutorial...
https://photography-on-the.net/forum/showthre​ad.php?t=684724
https://photography-on-the.net/forum/showthre​ad.php?t=514472
http://www.dpchallenge​.com/tutorial.php?TUTO​RIAL_ID=68 (external link)
--Howard
SmugMug (external link) | G+ (external link) | HJW Photography (external link)
7D Mark II | 6D | Σ 35mm f/1.4 | EF 50 f/1.4 | EF 24-70 f/2.8L II | EF 135 f/2L | EF 70-200 f/2.8L IS II | EF 100 f/2.8L Macro | Tamron 150-600
HrcRacing
Oct 04, 2011 21:53 as a reply to  @ Merovius's post |  #4
Great. Thank you guys.
Robert
tonylong
...winded
Gallery: 60 photos
Oct 04, 2011 22:40 |  #5
With Elements 4, you can use Layers, but there is not a "standard" layer mask, which can be very useful for this type of thing, and will show up in various tutorials and discussions.
I'm not sure if the add-on program Elements+ supports Elements 4, try finding that plug-in and checking it out.
Without that, there is a "work-around" for setting up a "mask" that will work for Elements -- you open a blank layer beneath each image layer above your background layer. You then select the image layer above one of the blank layers, then press Ctl and click the blank layer so that they are both selected with the top image layer "active". Then You will use the Layer->Group command (Ctl-G). The two should now be "linked" with the blank layer inserted a bit.
As is, the blank layer is "masking" the image layer, with white. Click on that mask layer and use the eraser tool to erase some of the white, and you should see that part of the image layer "revealed". Use the brush tool to paint over an erased/transparent part of the mask and you can "hide" the image layer in that part.
It's been a few years, but I believe I got that right -- play around with it and see if it works, or, hopefully, you can get Elements+, which adds Layer Mask funtionality!
Tony
HrcRacing
Oct 04, 2011 23:27 |  #6
tonylong wrote in post #13206566 (external link)
I'll give this a go for sure. Thank you. :D
Robert
kyballer14
Oct 06, 2011 13:14 |  #7
can this be done on Lightroom 3?
tonylong
...winded
Gallery: 60 photos
Oct 06, 2011 13:22 |  #8
kyballer14 wrote in post #13213783 (external link)
No, Lightroom is not an app with a built-in "graphical manipulations" editor.
Recently, a Lightroom plug-in called "Perfect Layers" was released that would have some capabilities if you don't have an app like Elements, Photoshop, Gimp or another image editing app. I don't know how much Perfect Layers costs -- you'd have to do a search for it and learn about it. You may be better off springing for Elements.
Tony
René ­ Damkot
Oct 08, 2011 03:46 |  #9
tonylong wrote in post #13213809 (external link)
^^^ This
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
2,143 views & 0 likes for this thread, 6 members have posted to it.
How do you do this?
493 guests, 124 members online
