Thread started 04 Oct 2011 (Tuesday) 21:42
No C.fn when flash is mounted?
Rolfe ­ D. ­ Wolfe
Joined Aug 2011
Oct 04, 2011 21:42 |  #1
So i hope this is the right section-
I just acquired a 420EX and when i was playing with it earlier i noticed that when i went into the menu and checked out the c.fn it would say that the flash was either off or not attached....which it was....and on.....lol.
It was set on flash...not slave....
and on the green dot....not HSS....
i had a pilot light and the flash does work....as i have test shots in a separate thread...
did i miss something?
I ran through the user manual but i did not see anything for this issue....just what c.fn actually exist....
any ideas?
Support the forums - donate here
macroimage
Oct 04, 2011 23:28 |  #2
The 420ex doesn't have custom functions. It is a good flash but is more for automatic e-TTL metering. You can also use it with high speed sync and second curtain sync but it doesn't have many other features.
Photo Gear
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Oct 05, 2011 00:42 |  #3
Rolfe D. Wolfe wrote in post #13206334 (external link)
Do you mean the camera's Flash Control Menus? The 420EX is not able to be controlled that way.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
Rolfe ­ D. ­ Wolfe
Joined Aug 2011
Oct 05, 2011 07:03 as a reply to  @ CliveyBoy's post |  #4
Ok thats what i figured.
Thanks!
msowsun
Gallery: 14 photos
Oct 05, 2011 08:35 as a reply to  @ CliveyBoy's post |  #5
The 420EX predates the in-camera menu interface, but it does have some items available in the camera flash menu.
(same for other older flashes like the 430EX, 550EX, 580EX, and some 3rd party)
In the "External flash func. setting" menu, you will see some items available, and some "Grayed Out" :
Main Flash Menu: Only ETTL II available
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo7/IMG_0340.jpg
Shutter sync: 1st and 2nd curtain (HSS must be selected on flash body)
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo7/IMG_0341.jpg
Showing HSS after selected on flash body
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo7/IMG_0344.jpg
ETTL: Evaluative or Average
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo7/IMG_0342.jpg
No Custom Functions available (420EX has no Custom Functions) (the 430EX and 550EX both have CF, so I wonder what they would display?)
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo7/IMG_0343.jpg
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
Rolfe ­ D. ­ Wolfe
Joined Aug 2011
Oct 05, 2011 12:01 as a reply to  @ msowsun's post |  #6
Ya that's the menu i have.
Ok just wanted to make sure that there was 0 problems with my flash unit since i bought it from ebay.
SMP_Homer
Gallery: 25 photos
Oct 05, 2011 12:08 |  #7
msowsun wrote in post #13207894 (external link)
They show the same thing - basically they are incompatible with this menu option
EOS R / 7D2 / 1D IV
24-105L, 100-400L, 100L, 300 2.8L, 1.4x II / 2x II
Sig35A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
600EX-II X3, 430EX-III X3
1,357 views & 0 likes for this thread
Latest registered member is protocolscg
1456 guests, 283 members online
