Thread started 05 Oct 2011 (Wednesday) 12:45
need help on how to achieve a shot
charlie_merrifi
Oct 05, 2011 12:45 |  #1
I want to do a shot of a model outside at night in the rain. I have two ab800 strobes. And two sigma flashes. I want to gel the flash with say a blue gel to make the rain behind/around her colored. And use my ab800 to light her. How can i pull this off without drowing out the colored rain.
Canon 5D classic, Canon XS, Sigma 24-70 2.8 HSM, EF 50mm 1.8 II, EF-S 18-55mm f/3.5-5.6 IS Lens,Canon EF 75-300mm f/4.5-5.6 III, Sigma Ef-500 DG super flash, Sigma EF-530 DG Super Flash
Wilt
Oct 05, 2011 13:06 |  #2
You are really talking about two exposures in one!
  • Exposing your subject, illuminated with one or two lights
  • Exposing the raindrops in the background, with one gelled light (and this is probably a different exposure in order to get better color saturation of the bluish rain)
...but the problem is that in illuminating the subject, the rain in the foreground will be illuminated white, not blue.
MichaelAnthonyPhotography
Joined Sep 2011
Oct 05, 2011 13:51 |  #3
Wilt wrote in post #13209093 (external link)
unless you can use some type of a snoot
Santa Clarita Wedding Photographers - Michael Anthony Photography (external link)
Los Angeles Photography Blog (external link)
PacAce
Joined Feb 2003
Oct 05, 2011 13:59 |  #4
MichaelAnthonyPhotogra​phy wrote in post #13209297 (external link)
If the subject is outside in the rain, there will always be rain between the subject and the llight unless you place something overhead to keep the rain out between them.
BTW, just as an aside, rain and AB strobes don't mix so make sure the strobes are well protected from the rain. Besides the risk of shorting out the strobes, there's an even bigger danger of electrocuting yourself when trying to make adjustments on the strobe. :shock:
...Leo
charlie_merrifi
Oct 05, 2011 14:39 |  #5
Im thinking of having the model stand outside my back door. Mee inside and alien bee inside shooting through a window
Hollywoodgt
Joined Mar 2011
Oct 05, 2011 23:17 as a reply to  @ charlie_merrifi's post |  #6
If I reading it right, have the model stand outside a garage door so your equipment stays dry placing the subject right out side......back lighting with gels will require a shelter for that light. Hope I was understanding the shot?
www.Jeffreyantonphotog​raphy.com (external link) http://www.modelmayhem​.com/jeffreyanton (external link)
Bodies:5D Infared 5D MK II/5D MKIII 4 Travellites 750R
18=55mm/55-250mm/50mm Ef1.8/70-200 ef2.8L IS II/85mm 1.2L II/24-70mm 2.8L II/16-35mm 2.8L II 2X Ext II
(3) 430EX/(3) remotes/2umbrellas plus assortment of defusers
Jarrad
Joined Jan 2005
Oct 06, 2011 02:05 |  #7
Gel the subject in the opposite color that you want the rain to be and use the neutral reference for white balance. If you go a full CTO and then correct it post with WB everything that isn't lit by the gelled light will be a full CTB.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Oct 06, 2011 09:31 |  #8
Does she have to get very wet? Why not set up the shot & have a couple people with hoses put the "rain" right where you need it?
And you get to stay dry. ;)
charlie_merrifi
Oct 07, 2011 08:27 |  #9
Actualy i was thinking that.
Dermit
Joined Nov 2005
Oct 07, 2011 09:36 |  #10
PhotosGuy wrote in post #13212978 (external link)
I vote this way.... and how about maybe pumping water with blue dye in it to make it blue instead of gels on the lights...
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
bespoke
Oct 07, 2011 23:35 |  #11
thats exactly what i did for this shot the other day
IMAGE: http://farm7.static.flickr.com/6110/6209630910_775c6061e6_o.jpg
IMAGE LINK: http://www.flickr.com/​photos/peterln/6209630​910/  (external link)
Untitled (external link) by table4one? (external link), on Flickr
Retouching (external link)Photography (external link)Instagram (external link)
5D3 & 5D2s | 24 TS-E II, 24-70 II, 85L II, 100L, 70-200L II, 35 & 85 Zeiss ZE, Samyang 14, Sigma 50
Hasselblads + Leaf Aptus MFDB, Fuji X100, Epson 3880/9890
2,878 views & 0 likes for this thread, 9 members have posted to it.
932 guests, 148 members online
