Thread started 05 Oct 2011 (Wednesday) 18:04
Buyers Guide to Softboxes?
Peacefield
Oct 05, 2011 18:04 |  #1
I have a 24x36 Calumet softbox that came with my Genesis kit. I'm very happy with it and would like to invest in a larger one; maybe around 4x5 or 4x6. The variety of offerings and disparity in price is a little overwhelming. Can someone guide me a little with what I want to look for and what makes one better than another?
Also, of course, I'll need it to be compatible with my Genesis lights.
Thanks.
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
LBaldwin
Oct 05, 2011 18:22 |  #2
I don't have any direct expereince with Genesis lights. But the Calumet softboxes are probably mid level quality wise. My own personal favorite is Chimera. I have had really good luck with them, and more importantly customer service. The construction is top notch.
Often softboxes in general will pop out the corners the bows will bend or break and mount will become loose. Chimera may or may not do the same. But when you call customer service they replace or repair quickly if they can.
Les Baldwin
http://www.fotosfx.com (external link)
bobbyz
Oct 06, 2011 09:25 |  #3
I am happy with photoflex, not top of the line but very good quality for the money. Grids are quite reasonable when you compare cost of the grids of some other brands.
Fuji XT-1, 18-55mm
Peacefield
Oct 06, 2011 12:05 |  #4
What about softboxes vs octaboxes. Is there a reason to prefer one over another?
lwest99
Oct 07, 2011 23:19 |  #5
Peacefield wrote in post #13213532 (external link)
They are very close. Biggest difference for me is the shape of the catchlights. The octa might get a little wrap but IMO it is not much of a difference.
KurtGoss
Oct 08, 2011 19:55 as a reply to  @ lwest99's post |  #6
THe main difference with a octabox vs. a rectangle softbox depends on the subject.
Octabox tends to give a better catchlight on a waist up or closer face shot, whereas the a tall 6 foot softbox is ideal for a full body shot - giving equal lighting from the feet to the head. I don't use an oct on fully body shots, but I will use tall rect softboxes on the body in conjunction with a beauty dish on the face.
Then you have rectangular stripboxes, that give a more narrower control of light, for a more controlled wrap. Very useful on male models when you are trying to accentuate body muscle. Also good for hairlights.
There are no set rules for how you use a softbox... experiment!
bobbyz
Oct 08, 2011 21:51 |  #7
One thing I have seen is that regular octas are quite shallow (depth wise) compared to softbox.
Fuji XT-1, 18-55mm
Peacefield
Oct 09, 2011 06:08 |  #8
bobbyz wrote in post #13223271 (external link)
That's the kind of insight I'm looking for. I see some of the distictions (depth, shape, silver or white inside, etc.) and am not sure how those difference affect the quality, consistency, and shape of the light produced. Can anyone expand on that?
eduardofrances
Oct 09, 2011 15:37 |  #9
Peacefield wrote in post #13210346 (external link)
Thanks.
There are quite a lot of offerings and some better than others, sometimes price is indicative of the quality in this case...
The most common problems with no name softboxes (with some exemptions) are: Color casts and not enough diffusion, the first one could be caused for a variety of reasons (difussion pannels and bounce material not treated against fluorescence, color casts on the materials, etc).
Also you have to factor that each manufacturer uses a different process to treat their materials so you will find slight differences in color from one brand or the other.
The best advice I can give you is to stick to the same brand you already have because that will avoid the problem of different color casts :) (which are a PITA to remove in PS later).
The only exemption I can vouch for is Viewfinder Photography (UK) foldable octas, those things are REALLY well made and they are pretty neutral, I can recommend them.
Good brands:
Chimera, Photoflex, Calument, Elinchrom, Profoto, Viewfinder Photography (UK).
Avoid like the plague:
Interfit, Visico and no name brands (unless there is some specific recommendation from people around here).
http://flickr.com/phot​os/eduardofrances/ (external link) :D
Peacefield
Oct 10, 2011 07:19 |  #10
Excellent info; thanks, Eduardo!
bobbyz
Oct 10, 2011 09:11 |  #11
One more thing, cheaper variants usually come with crappy grids. Photoflex grids are very nice for the price. Other brands can get quite expensive. Chimera has options for front diffusion material like 1/2 stop 1/4 stop unlike other brands. Elinchrom boxes don't have grid options from what I hear on POTN.
If buying photoflex I would but the ones with silver/white insert options. So you can put silver insert if you need little more punch. I have the basic litedome model of 24x36 softbox. The 5' octa that I have did come with silver and gold inserts. Never used gold but silver is quite nice.
Fuji XT-1, 18-55mm
bobbyz
Oct 10, 2011 09:12 |  #12
Another good brand is Larson.
Fuji XT-1, 18-55mm
LBaldwin
Oct 11, 2011 02:48 |  #13
The reason I stay away from anything other than Westcott, or Chimera, is that I have had lesser boxes and some umbrellas take a crap during a shoot. I have had Photoflex loose the shiney silver from the inside, and some other brands just not fit as well. You need to know that if a model dumps the lamp and stand over that the softbox is going to take the hit without tearing. Save your pennies get the good stuf used if you can. You can spend all day getting referrals from others, but in the end how many times do you want to buy the gear. I just had a westcott reflector bust the main spring on pop up. I called them, they told me that it was 10 years old and way out of guarentee. They gave me a great coupon to use when I re bought and it came to nearly 40% off. My gear gets used all the time, and in a 40 knot wind it's kind to it. But it keeps on going.
Les Baldwin
4,959 views & 0 likes for this thread, 6 members have posted to it.
1592 guests, 137 members online
