Thread started 02 Nov 2005 (Wednesday) 16:03
Problem burning CD-R's
InskiP
Nov 02, 2005 16:03 |  #1
Why won't some CD-R's burn? First of all, I'm on a Mac, don't know if that makes a difference or not, but I've never had problems burning before.
Anyway, I got some TDK disks for computer burning and like every other one will say, "error occured while trying to burn-disk cannot be used." But the next one WILL work fine. I used Sony CD-R's before and had no problems whatsoever. Just wondering if someone might know what the deal is??
Also, I thought I heard somewhere that you can use DVD's to burn photos to, and they have a lot more space. Is this true? Is it the same process as burning CD-R's?
Canon 20D
50mm 1.8
85mm 1.8
580EX(still trying to figure it out)
Lightsphere II
PS CS2
Mac OSX
Apple Studio Display(LCD)
www.vip.smugmug.com (external link)
Critique and edits welcome
JonathanSQ
Joined Jun 2005
Nov 02, 2005 16:06 |  #2
Not sure bout the CD-R problems. But yes, you can use DVD-R (or whichever format the disk is)
for data storage such as photo storage. They DO have a lot more space than CD-R/CD-RW's to.
Pretty much same process from what I've observed. BUT you need a DVD-burner to do this (of course).
Not used Mac's before also, not sure if that makes a diff or not..
Note: You can edit my photo just tell me how you did it ;)
Canon EOS 350D/OPTech Strap | Canon EF-S 18-55mm | Canon EF 50mm F/1.8 MkII
| Tamron 75-300mm
Bogen 679B Monopod |
Misc. CF cards, filters, bags, laptop, software, etc.
http://JWSquire.com (external link) - Home Page |
:D The desire to learn :D
robertwgross
Joined Nov 2002
Nov 02, 2005 17:18 as a reply to  @ JonathanSQ's post |  #3
On my machine, I have a combination CD/DVD write drive.
If I try to write a blank CD, it is a little particular about the blank media. The cheapest media is out completely, since 50-70% will seem to fail during the write process. The ones that seem to write successfully often fail later when it is time to be read. So, they are worthless to me. Good ones of one particular brand work correctly 98% of the time. As a general rule, the better the blank is, the faster it can be written. And with some blanks, writing it slower gets better results.
For DVD blanks, you get five or more times as much capacity. Here, my drive will accept only one of the DVD formats to write with, and I don't know why. However, if I buy one of two brands of the correct format, then they work correctly 98% of the time.
So, see where your system's limitation is.
---Bob Gross---
Huckaback ­ Photo
Joined Jan 2005
Nov 02, 2005 17:46 |  #4
Inskip
There are different write speeds on all CD's and DVD's, just make sure you have got compatible discs for you CD burner.
also if the drive is old it may be wise to to clean it.
if intermitant problems it could be software probs, if pos try a disc that wont work on a different machine at least this would give a clue to the problem.
Martin (Huckaback Photo)
Old photographers never die. They just go out of focus
Huckaback ­ Photo
Joined Jan 2005
Nov 02, 2005 17:49 |  #5
Should have mentioned
4.7 Giga byte on DVD
650 to 700 Mb on cd rom
Desertraptor
Gallery: 212 photos
Nov 02, 2005 17:51 |  #6
Try burning at the slowest speed this will sometimes over come certain issues.
I have a Panasonic DVD/CD burner dual layer and use cheap discs generally with no problems. Usally 1x is the best. It will take a while but generally will burn well.
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
johnnybfan
Joined Jan 2005
Nov 02, 2005 22:20 |  #7
I just had to replace my DVD/CD-R burner. It was only burning whenever it felt like it, but it wasn't ruining the CD-R's in the process. It would say that the write process was complete but not do anything at all. After pulling out what little hair I have left I decided to replace it. And my frustrations have disappeared! lol I use the cheapie CD-R's for everyday things like music or short-term photo storage and they work fine - haven't had any problems yet.
jim
40D w/Grip X 2, Canon 10-22, Canon 24-70mm f2.8L
, Canon 100-400L IS, Nifty Fifty, Canon 430 EX Flash
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Nov 03, 2005 00:18 |  #8
Try setting the burn speed to a slower speed.
Doc Klepper in the USA
I
jboyd
Joined Mar 2003
Nov 04, 2005 09:04 |  #9
I'm glad I am not the only one with problems burning CD/DVD's. I even went out and bought Roxio's Easy Media Creator because the shareware programs I was using were not working - errors all the time. I get the same errors with Roxio. :( The only way I can burn is to import the photos into PS Album and burn from there. Anything else, I get errors.
Jackie Boyd
40D | 20D | 10D | 16-35 f/2.8L | 24-70 f/2.8L | 70-200 f/4L | 85 f/1.8 | 50 f/1.8 | Tamron 90 f/2.8macro | Tamron 28-75 f/2.8 XR Di LD | 550EX | AlienBee 800's | and too many other accessories!
dicky109
Joined Feb 2003
Nov 05, 2005 00:59 as a reply to  @ jboyd's post |  #10
I had a similar problem on my PC. Tried different media but it made no difference. Searched the net and all results said it was a software issue and gave fixes. None of them worked, so as a last resort called Dell support.
Tech said the drive was shot, but I didn't really believe him. He said he'd send out a new drive & a tech to install it. I didn't even know I had a 3yr warranty (this was about 2 1/2 years into it), never mind it being on-site, so since it was free, and since I was able to have him come at my convenience accepted it!
For the first time in almost 20 years of dealing with Dell (going back to when they were called "PC's Limited") one of their techs got it right and I've had no problems since.
If you're under warranty, contact Apple, or if you have access to another machine, try swapping drives to see if that's the problem.
Good luck
Rich B
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt"--Bertrand Russell
1,629 views & 0 likes for this thread, 9 members have posted to it.
1221 guests, 125 members online
