I own the Radio Popper JRx system, and would like to use my 430EX ii as fill flash on camera while still triggering my JRx system. I own a 60D, so I don't have access to a PC port. Has anyone used the Yungnuo FC-681
to solve this issue?
M.
mcarriere987 Mostly Lurking 10 posts Joined May 2011 Location: Winnipeg, MB More info | Oct 09, 2011 23:21 | #1 I own the Radio Popper JRx system, and would like to use my 430EX ii as fill flash on camera while still triggering my JRx system. I own a 60D, so I don't have access to a PC port. Has anyone used the Yungnuo FC-681 _____________
Oct 10, 2011 13:29 | #2 Anyone? _____________
Oct 10, 2011 15:24 | #3 Looks good, as long as you are able to neatly contain the cable.. CANON 5D MKIII x 2 / CANON 50D / CANON 550D
Purplecow Member 178 posts Joined Dec 2010 Location: Southern California More info | Oct 10, 2011 17:54 | #4 You can't use E-TTL and the JRx system. It'll only allow manual flash trigger.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Oct 10, 2011 21:04 | #5 Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Oct 10, 2011 22:48 | #6 Purplecow wrote in post #13231326 You can't use E-TTL and the JRx system. It'll only allow manual flash trigger. 60D has a wireless E-TTL flash trigger system that will work with your 430ex IIs. You should be able to trigger two groups A & B. Set one of your flash to A slave and the second one to B slave. Disable the pop-up flash for image exposure. You should be able to control the flash ratio between group A and B from the camera menu which is a bit cumbersome. Keep in my that this would be an optical trigger. Indoors, the bounce flash should be enough to trigger the slaves even though you don't have a line of sight. Experiment with this before you buy any other gear. You have not understood my question. _____________
Oct 10, 2011 22:52 | #7 Unfortunately, the JRx don't connect via PC Port. They connect via the hotshoe. _____________
FlashZebra This space available 4,427 posts Joined Mar 2006 Location: Northern Kentucky More info | Oct 10, 2011 22:58 | #8 mcarriere987 wrote in post #13232661 Unfortunately, the JRx don't connect via PC Port. They connect via the hotshoe. M. The JrX transmitter has a port that a flash sync cable can be connect to in addition to the flash foot sync contacts.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Oct 10, 2011 23:54 | #9 Yep, flash on the hotshoe, cable from Lon to connect the camera PC port to the transmitter. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
emdzey01 Senior Member 349 posts Likes: 1 Joined Apr 2008 Location: SoCal More info | Oct 11, 2011 01:59 | #10 Unfortunately, Canon has done away with the sync port on the 60D. my name is mjay.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Oct 11, 2011 02:40 | #11 The link I posted earlier spells out what I do pretty clearly. I put a flash in the hotshoe and I velcro the skyport transmitter to the side of the flash head, attached to the camera sync port with a locking sync cable. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
emdzey01 Senior Member 349 posts Likes: 1 Joined Apr 2008 Location: SoCal More info | Oct 11, 2011 03:21 | #12 tim wrote in post #13233386 The link I posted earlier spells out what I do pretty clearly. I put a flash in the hotshoe and I velcro the skyport transmitter to the side of the flash head, attached to the camera sync port with a locking sync cable. Found it in a different post on your link, thanks. The first post had no description on how or where you mount your trigger; only mentioned that your trigger is connected via pc sync. I only bothered to read through the first post; thinking it would be comprehensive enough. my name is mjay.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Oct 11, 2011 03:37 | #13 Ah yeah I could do that some time, next time I get the lot out. It's a bit of a pita to drag it all out, it's damn heavy! Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is Frankie Frankenberry 1224 guests, 124 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
