If picking between these two, what's the consensus here? They seem to be comparable in price, yet they are hardly talked about in the same sentence? It seems the Sigma would be a lot heavier, however they offer the same range.
ar10 Junior Member 20 posts Joined Jun 2011 More info | Oct 10, 2011 16:32 | #1 If picking between these two, what's the consensus here? They seem to be comparable in price, yet they are hardly talked about in the same sentence? It seems the Sigma would be a lot heavier, however they offer the same range.
botw Goldmember ![]() 1,157 posts Likes: 5 Joined Feb 2009 Location: Potomac, MD More info | Oct 10, 2011 16:40 | #2 Canon advantages: size, weight, sharpness, weather sealing, super-fast and accurate focusing (not that the Sigma is bad, but in good light the Canon is great)
Sirrith Cream of the Crop More info | Oct 10, 2011 17:08 | #3 I had the f4 IS before, and if I was buying a new lens in that price range and in the 70-200 range, unless I needed the light weight of the canon, I'd go for the sigma no question. -Tom
Its going to depend on what you are wanting to do. The F2.8 will work better for you in low light if that is what you are needing it for. I have not used the Sigma, but have good things about it. Thomas aka Huck - Hinton, Oklahoma - Gear List/Feedback
Oct 10, 2011 22:37 | #5 I haven't used the canon f4 with IS. I just upgraded my f4 non IS with the sigma. CANON 6D - SONY A6000
Sirrith Cream of the Crop More info | Oct 11, 2011 03:39 | #6 botw wrote in post #13230975 ![]() Canon advantages: size, weight, sharpness, weather sealing, super-fast and accurate focusing (not that the Sigma is bad, but in good light the Canon is great) Sigma advantages: 2.8 better build (I've held both, that is my opinion), includes tripod mount ring, zoom and MF rings feel smoother, comes with a proper soft case instead of a floppy bag, much longer warranty What do you need? Fixed that a bit. -Tom
muusers Goldmember ![]() 1,024 posts Joined Sep 2009 Location: Haarlem, Netherlands More info | Oct 11, 2011 04:38 | #7 Sirrith wrote in post #13233482 ![]() Fixed that a bit. Better build? So NO weathersealing and plastic materials are BETTER? 50D + 17-55 | s100 | flickr
Sirrith Cream of the Crop More info | Oct 11, 2011 07:01 | #8 muusers wrote in post #13233566 ![]() Better build? So NO weathersealing and plastic materials are BETTER? Odd. The f4 IS is plastic as well. -Tom
phreeky Goldmember 3,514 posts Likes: 15 Joined Oct 2007 Location: Australia More info | Oct 11, 2011 07:04 | #9 muusers wrote in post #13233566 ![]() Better build? So NO weathersealing and plastic materials are BETTER? Odd. Since when isn't the F/4 IS made up largely of plastic? Not that I consider plastic a bad thing anyway, and I agree I do not see how you could criticise the F/4 IS build quality.
ceegee Goldmember 2,320 posts Likes: 7 Joined Mar 2008 Location: Montreal, Quebec More info | Oct 11, 2011 07:23 | #10 ar10 wrote in post #13230938 ![]() If picking between these two, what's the consensus here? They seem to be comparable in price, yet they are hardly talked about in the same sentence? It seems the Sigma would be a lot heavier, however they offer the same range. I had the Sigma non-OS and swapped it for the Canon f4 with IS (and am much happier). The weight was a big factor for me. I found I was leaving the Sigma at home more often than not, just so I wouldn't have to carry it around with me. Of course, it depends how you're going to use your lens. Mine is often used for activities with my kid, and I find the smaller build of the f4 IS to be much more convenient. I also use it for portraits and outdoor sports, where the Canon also shines. The f4 IS is an outstanding lens in every respect - very hard to find fault with it. Gear: Canon 7D, Tokina 12-24 f/4, Canon 24-105L f4, Canon 70-300L, Canon 60 macro f/2.8, Speedlite 580 EXII, 2x AB800
muusers Goldmember ![]() 1,024 posts Joined Sep 2009 Location: Haarlem, Netherlands More info | Oct 11, 2011 08:32 | #11 Sirrith wrote in post #13233872 ![]() The f4 IS is plastic as well. Have you used either of those lenses? Edit: Actually now that I think about it a bit more, I'm sure the sigma has a section made from metal near the mount before the zoom ring, so in fact the f4 IS has MORE plastic than the sigma. I've owned a 70-400 f4 IS for over a year. The external housing is coated metal. The black filter thread, the switches and the focus window are plastic, the focus and zoom ring rubber. Overall the thing is build like a tank ánd weather sealed. phreeky wrote in post #13233875 ![]() I do not see how you could criticise the F/4 IS build quality. I'm not. In fact, i cant see how the sigma's build quality could be better than that of the F4 IS. 50D + 17-55 | s100 | flickr
Sirrith Cream of the Crop More info | Oct 11, 2011 09:02 | #12 muusers wrote in post #13234182 ![]() I've owned a 70-400 f4 IS for over a year. The external housing is coated metal. The black filter thread, the switches and the focus window are plastic, the focus and zoom ring rubber. Overall the thing is build like a tank ánd weather sealed. Sorry to burst your bubble, but its not coated metal. Its plastic. Thin plastic at that. I've owned the f4 IS before and own the non-IS now. -Tom
XxDJCyberLoverxX Goldmember ![]() 1,139 posts Gallery: 30 photos Best ofs: 1 Likes: 144 Joined Oct 2009 Location: Shinjuku-ku, Tokyo, Japan More info | Oct 11, 2011 09:50 | #13 I'm also interested. As far as optical performance, would the Sigma 70-200mm OS be on par with the Canon F4L IS? Daniel
Sirrith Cream of the Crop More info | Oct 11, 2011 09:55 | #14 Performance will be similar. You won't notice any difference except maybe the colours unless you pixel peep. -Tom
muusers Goldmember ![]() 1,024 posts Joined Sep 2009 Location: Haarlem, Netherlands More info | Oct 11, 2011 10:25 | #15 Sirrith wrote in post #13234267 ![]() Sorry to burst your bubble, but its not coated metal. Its plastic. Thin plastic at that. I've owned the f4 IS before and own the non-IS now. The internal parts are probably metal, but then that goes for pretty much all lenses. *Sigh* You sure are persistent, even if you've got your facts wrong. I'd say call/mail canon... Ask them. 50D + 17-55 | s100 | flickr
y 1600 |
Log in Not a member yet?
Registered members may log in to forums and access all the features: full search, image upload, follow forums, own gear list and ratings, likes, more forums, private messaging, thread follow, notifications, own gallery, all settings, view hosted photos, own reviews, see more and do more... and all is free. Don't be a stranger - register now and start posting! |
Latest registered member is Digital Novice 912 guests, 224 members online Simultaneous users record so far is 15144, that happened on Nov 22, 2018 |
