Thread started 11 Oct 2011 (Tuesday) 12:40
iMac 3.4 I7
sf1
Oct 11, 2011 12:40 |  #1
I picked up a new 2011 27 inch iMac 3.4 I7 with a 1 TB hard drive, 1 gig video card and 4 gigs of RAM refurbished from Apple for $1869 - a saving of $330 over new. I have a refurbished MBP for 4 years now, so I didn't feel the need to go new.
I ordered 8 gigs of after market RAM and installed them in 1 minute and now have 12 gigs. I also picked a 3 TB 7200 rpm FW 800 hard drive for back-ups.
I had a chance to play with Aperture 3, NIK and CS5 using my 5DII files. All I can say is that I am happy with the speeds. There is zero lag time between any adjustment brushed in Aperture, NIK or CS5. Essentially you press the button for the brush and it works - period. This machine is super snappy from what I had - 15 inch MBP at 2.4 core duo and 4 gigs of RAM.
I did a migration assistant from the MBP to the iMac using the FW 800 drive. It was simple and easy. The iMac is virtually the same as the MBP - everything was set up identical to the MBP using the migration assistant - right down to the bookmarks, dock, etc.
I did notice at 4 gigs of RAM on the iMac that I was getting the ball of death, but followed this and it cleared it up immediately: http://support.apple.c​om/kb/ht2409 (external link)
Canon 5DII, Canon 1D Mark II N
Canon 24-70 mm f/2.8 L, Canon 85 mm f/1.8, Canon 70 -200 mm f/2.8 IS L, Canon 400 mm f/5.6 L, Canon 50 mm f/1.4, Manfrotto 055XPROB & 488 RC2
Canon Speedlites 580 EX, 430 EX II & 3 PW II, iMac I7, MacBook Pro, Aperture 3, CS5
MaxxuM
Oct 11, 2011 20:06 |  #2
Yep, its pretty easy :) You can download OnyX and do an automated cleanup with everything checked (except for browser cache if that matters) and it will re-index everything by default. It also cleans up a lot of clutter - just don't run a full cleanup job more than once or twice a month. Even then, it's doubtful you'll gain much by doing so since OS X likes to learn about your habits.
Have fun with your computer :)
Canajun
Oct 11, 2011 20:22 |  #3
sf1 wrote in post #13235302 (external link)
I've been playing around with Aperture and from time to time. It seems to "hang" or quit unexpectedly. But I suspect this is to do with Aperture. But granted I think 4GB is not sufficient.
So you only do this to clean up your folders. But since my iMac is less than 2 months old. This procedure is not necessary for me?
Jun.Roberto.Dizon.Greg​orio
My Photographic Gears.
I Like Shooting Animals Than People.
sf1
Oct 12, 2011 06:44 |  #4
MaxxuM wrote in post #13237331 (external link)
Yup, I have OnyX - but totally forgot about it. It would have done the same job. I am enjoying it....thanks.
Canajun wrote in post #13237400 (external link)
4 GB of RAM for Lion and Aperture 3 is just not enough. I would at least do a disk repair and run OnyX or the fix mentioned above. Even though my machine is new, I used migration assistant to essentially make the new machine identical to the older MBP. If you could, I highly suggest more RAM. 8 GB for the iMac runs less than $50
2,139 views & 0 likes for this thread, 3 members have posted to it.
iMac 3.4 I7
642 guests, 120 members online
