FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 12 Oct 2011 (Wednesday) 00:21
Outbuildings - Tonemapped and Stacked
Spike44
Oct 12, 2011 00:21 |  #1
I tried a number of different approaches to exposure stacking from a 3 bracket image. I included a HDRI for comparison but has had more tweaking applied than the blends below it. I tried the Photoacute but the sky was totally blown out (but with very low noise :) ). All have had auto curve adjustment and all have had a darkened sky added using the same technique and opacity in Photoshop....results follow:
1. The HDRI from Photomatix:
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/IMG_3741_2_3_TMskychngePPWWW.jpg
2. Fused from Photomatix (noise reduction applied):
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/IMG_3741_2_3_fusednoiseredwithcontrskywww.jpg
3. Fusion from Mediachance Dynamic HDR (strange sky artifacts):
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/MedChanceFusionIMG_3743www.jpg
4. Exposure stacking/blending from Photoshop CS5:
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/PSautoblend-with-contrsky.jpg
5. Manual exposure blending using luminosity masks from here
https://photography-on-the.net …showthread.php?​t=1098256:
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/Manual-blend-with-Luminosity-contrsky.jpg
Spike44
Oct 12, 2011 18:15 |  #2
I discovered a very good alternative for image stacking (I did not test the HDR option) - easyHDR. I am very impressed! It is not how the name sounds...it has many settings that you can tweak within the program including a histogram and PS-like curves adjustment. These are the 2 non HDR merge options as described on their site:
"Instead of generating a true HDR radiance map, there is a possibility to merge the photo sequence using a pseudo-HDR algorithm (called Smart Merge) or to generate an image stack (simple average). "
6. easyHDR smart merge with curves adjust no additional PS work:
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/IMG__3741_42_43_easyHDR-PROsmart-merg.jpg
7. easyHDR image stack with curves adjust no additional PS work:
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/IMG__3741_42_43_easyHDR-PRO-2stack.jpg
vmlopes
Oct 14, 2011 03:15 |  #3
I prefer image #1 out of the lot......
#2 looks like the foreground is very slightly over exposed
#3 as you say strange sky and flat
#4 shadow detail in the left hand of the frame is lost
#5 waaay too flat needs a contrast bump
#6 is good almost as good as #1 but not quite as much detail in the clouds
#7 detail in the clouds has gone and blown out
"I choose to live my life to a different tune of music., one which is not censored or wrapped so much with a blanket of over -regulation, Health & Safety gone mad, fear and blind compliance to anything you are told to do"........... Downfallen, RIP
J-Blake
Great Googley Moogley!
Gallery: 129 photos
Best ofs: 9
Oct 14, 2011 09:26 |  #4
I agree with Victor, that 1 and 6 are the best on the shots as presented, and if you took the sky from 1 and merged with 6 you'd have the best of the bunch. On the otherhand, I think you stopped to early on #5 and if you bring back the contrast you may have the best of the lot.
Jon
So much to learn, so little time.
A few worthy shots (external link)
Spike44
Oct 14, 2011 21:53 |  #5
Thanks for comments Victor and Jon. I agree with you both.
I was so impressed with the 2 easyHDR stacking processes that I tried a sample with true tonemapped/HDRI approach. (slightly different image). I applied similar Post work in Photoshop - I remain impressed.
To summarize/clarify, there are only 2 images tonemapped here - #1 above and #8 below.
8. easyHDR Tonemapped
IMAGE: http://i14.photobucket.com/albums/a323/rathgarb/44_3745_3746_easyHDR-PRO-2TMppwww.jpg
1,812 views & 0 likes for this thread, 3 members have posted to it.
1053 guests, 121 members online
