Thread started 13 Oct 2011 (Thursday) 19:48
...curious: how would you guys have handled this lighting situation?
banquetbear
Oct 13, 2011 19:48 |  #1
IMAGE: https://lh5.googleusercontent.com/-DVHM3Fa1Rkw/TpdokLNJBzI/AAAAAAAANks/Fd58un2mw28/s800/IMG_9999_377.JPG
I took this six months ago, and I was going through some old photos and I saw this and I remembered what went through my brain as I was shooting this, so I thought I'd throw it over to the POTN guys...
...this shot wasn't a keeper and it was during the rehearsals, and fortunately during the performance the sun had moved to a position where the lighting on stage was more constant. But my question is: in this lighting: what would you guys have exposed on? I chose to expose for the shaded areas, and tried to get shots of the girls only while they were in the shaded areas, but I'm curious how other members here would handle this.
Cheers!
www.bigmark.co.nzexternal link
emelvee
Oct 13, 2011 19:52 |  #2
I could be wrong, but I thought that as a general rule, you should expose for the brightest spot ...
Canon RP | Canon 6D | 70-200 f/2.8 I | 50mm f/1.4 | 16-35mm f/2.8 II | 580EX II x 2
Tumblr (external link)
yeow_Z
Oct 13, 2011 19:52 |  #3
flash is the answer for me.
webpage (external link)
emelvee
Oct 13, 2011 20:05 |  #4
yeow_Z wrote in post #13247845 (external link)
That too.
tonylong
...winded
Gallery: 60 photos
Oct 13, 2011 21:16 |  #5
Those can be tough shots for sure.
I hate blowing highlights of a scene, so I'll avoid it, meaning I have to crank a few things to get the shadows up there without messing up the highlights.
Raw is invaluable there! But it still can be a hassle!
You're definitely fortunate that the light changed in your favor. The last couple performances on bright sunshiney days that I shot I was not so fortunate:)!
Tony
Curtis ­ N
Master Flasher
Oct 13, 2011 21:33 |  #6
If I had to shoot that scene, the thought that would go through my mind would be "I'm screwed!"
Flash can help with this but only to a degree. You're limited by the power of the flash unit and the fact that it will make its own shadows. Also, the inverse square law will make it impossible to light the whole group evenly.
You can also expose for the sun and bring up the shadows in post as Tony mentioned but there's a limit there, too.
banquetbear
Oct 18, 2011 05:54 |  #7
...cheers all, thanks for your responses!
Curtis N wrote in post #13248298 (external link)
That, indeed was the thought that went through my head! Its hard to tell, but the bright light was only a sliver that covered the front of the stage, and only the occasional dancer crossed into direct sunlight, but it happened often enough to be annoying and for me to second guess how to shoot the scene...for those advocating flash, what would be your approach? Underexpose the scene and use the flash for fill?
1,637 views & 0 likes for this thread, 5 members have posted to it.
1349 guests, 130 members online
