Thread started 13 Oct 2011 (Thursday) 21:55
Most Basic E-TTL Flash Question
kitjv
Oct 13, 2011 21:55 |  #1
Please be patient with me. But I am not real comfortable with how E-TTL flash works (even after reading sections of the EOS Flash Bible). Please tell me if I got this right or not.
Suppose the camera is set in either Av or Tv mode with hotshoe-mounted flash unit turned on in E-TTL mode. With the shutter released pressed halfway, the camera will adjust for proper exposure based on ambient light only. When the shutter is completely pressed, the flash fires a pre-flash which is evaluated by the camera & stored in memory. Thus, to achieve the proper exposure when the flash itself fires, the camera adjusts the duration of the flash pulse. Is this correct?
Thank you for your patience.
windpig
Chopped liver
Oct 13, 2011 22:20 |  #2
Yes.
Any chance I can try and convince you to manually set your ambient exposure when your using your flash?
BTW, be sure and use FEL if you are going to focus and recompose.
Go ahead, spin the wheel.
kitjv
Oct 13, 2011 22:26 as a reply to  @ windpig's post |  #3
Thanks, Windpig. Obviously I am a neophyte when it comes to flash photography. I certainly understand the advantage of manually setting exposure for various situations when using ambient light only. Is there a particular advantage of doing so with flash?
windpig
Chopped liver
Oct 13, 2011 22:35 |  #4
ETTL on it's own can be prone to exposure issues depending on how well you know how to use it. Throwing another auto mode into the mix just makes it more difficult to get a handle on putting the exposure pieces together.
If you're not in conditions of changing ambient light, make a best guess manual exposure and check your LCD screen, if you're not happy with it, adjust and try another shot. Then add flash, adjust your Flash Exposure Compensation to taste. Generally, to make your subject pop out, you'd underexpose your ambient by a stop or so, then add your flash. Adjusting your FEC would be to compensate for a very dark or very bright subject/clothes or whatever may bias the ETTL metering.
kitjv
Oct 13, 2011 22:48 as a reply to  @ windpig's post |  #5
Point well-taken regarding manual exposure. Also, the idea of slightly underexposing the subject & using FEC to highlight the subject is appealing. I will definitely try it while I experiment with flash.
Thanks so much.
Robertogee
Oct 14, 2011 00:24 |  #6
Please invest in Syl Arena's "Speedliter's Handbook." He covers this (and everything else) in complete and understandable detail.
You'll learn exactly when, where and how to use manual flash, ETTL, manual camera with ETTL flash, etc.
He's big on learning to use and understand manual flash, so you know what ETTL is doing and how to compensate with it.
Lighting is EVERYTHING.
Good luck!
EOS 7D | EOS 40D | EF 85mm 1.8 | Canon 10-22 | Canon 50mm 1.8 | Canon 28-135mm | Tamron 17-35mm | Tamron 28-200mm LD | Tamron 70-300mm | 580 EX II | 430 EX II
windpig
Chopped liver
Oct 14, 2011 06:35 |  #7
One thing to remember also it you use TV or AV mode, is that it may put yu down into a shutter speed that is not hand holdable. In manual, you are totally aware of the shutter speed.
AntonLargiader
Oct 14, 2011 06:41 |  #8
In other words, when you're in Av or Tv the camera will still try to make a correct exposure without the flash, then try to add flash for the subject. So you end up with what might be an unnecessarily long shutter or wide aperture.
By using M, you can choose both of them yourself and then let ETTL bring the exposure up. Obviously you have to start with settings that CAN be exposed with flash, but that comes with a bit of experience.
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
Tiberius
Oct 14, 2011 06:42 |  #9
Have a read of my "How to use manual flash (external link)" tutorial.
My photography website!PHOCAL PHOTOGRAPHY (external link)
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Oct 14, 2011 07:55 |  #10
AntonLargiader wrote in post #13249487 (external link)
That is true for indoor, low lighting situations. I have the camera on M for that. Outdoors during the day AV is pretty safe to use.
Image Editing OK
kitjv
Oct 14, 2011 08:03 as a reply to  @ digital paradise's post |  #11
I will check out both the Speedliter's Handbook & Tiberius47's tutorial. I really appreciate this information. I'm the kind of guy who wants to know why things work the way that they do. This way I can analyze a situation & adjust accordingly. Thank you so much.
digital ­ paradise
Gallery: 157 photos
Oct 14, 2011 08:12 |  #12
I was in another forum, on another site and one person started a thread about this. He was asked to shoot a company function and was not too familiar with his flash. He set his camera to AV and had a horrible night. He had the slow shutter speed issues mentioned in this post. He had to keep bumping up the ISO which he did not want to and all his images were underexposed. In his opening statement he was about to give up photography.
Poor fellow made that common mistake. Did not realize that in AV you need to satisfy your light meter and your flash acts as a fill. In M you can ignore the light meter even if it shows it is underexposed and now the flash will provide the necessary light for your subject/s. That was a long thread with all kinds of suggestions. There was only one answer - M mode (or a high IS0 in AV) and I'm not sure the people who knew that answer ever really convinced him. It was interesting to see all the suggested solutions. A very educational thread.
Image Editing OK
GeeMack
Gallery: 10 photos
Oct 14, 2011 08:31 |  #13
Robertogee wrote in post #13248922 (external link)
Good luck!
+1 Good book. Cleared up a lot of confusion for me.
7D, 50 f1.8, 17-55 f2.8, 70-200 f2.8 II, 100-400 f4.5-5.6L, 2x TC III, 580EX II, 430EX, 568EX II, 622C
glmphotos.zenfolio.com (external link)
kitjv
Oct 14, 2011 10:03 |  #14
Tiberius47 wrote in post #13249491 (external link)
Tiberius47, I'm curious. Having read your tutorial above, I have a question. After adjusting the camera's exposure for the background in manual mode, you recommend manually adjusting the flash to achieve proper exposure for the subject. Makes sense to me.
Question: After I expose for the background with the camera in manual mode, can I achieve proper flash exposure by setting the flash to the E-TTL mode & using flash exposure compensation to make adjustments?
Thank you.
windpig
Chopped liver
Oct 14, 2011 11:16 |  #15
kitjv wrote in post #13250143 (external link)
Thank you.
Yes.
I wouldn't use manual flash unless the flash was on a stand or the flash/camera was on a tripod. Just my opinion.
3,800 views & 0 likes for this thread, 9 members have posted to it.
1040 guests, 107 members online
