So there are occasional gripes and questions regarding how to eliminate grain and noise when tone mapping an HDR dataset.
THere are, of course, plenty of techniques but most often the response is something to the effect that one should use a raw converter, use the noise reduction in that conversion to handle the noise and then merge to HDR.
Here's an alternative that is much more effective, mostly because the technique relies upon the notoriously awesome and confounding application known as Zero Noise.
One of the features of Zero Noise is the ability to output a bracketed set of 16 bit TIFFs with the desired EV spacing. Why is this even remotely interesting? Because what Zero Noise is capable of doing is taking your raw bracketed data, combining the best, noise free pixels across the exposure range and then delivering to you a bracket, ready for merging and tone mapping, that IS NOISE FREE. This is nothing new, I just have not had the time to get around to addressing the often vexing issue of noise and artifact in HDR tone mapping.
I will post an example of what I mean once I get a chance to pick and process an easy to appreciate image set.
People, this is good stuff. For those of you who do not know what Zero Noise is, google it. It is a windows application written by forum member "_GUI_" and it is pretty fantastic. It is utilitarian and requires some patience and work to understand what is going on and how to get the application to do what you want. I wrote a mini-tutorial about the basics a while ago:
https://photography-on-the.net/forum/showthread.php?t=775795
I run it on my mac in Parallels (Win XP and Linux) as well as Wine.
Stay tuned....
Kirk
you just need to create a folder called c:\dcraw\ and copy dcraw.exe on it.
