I hope I have this sized correctly for posting. I know I should do something with her hair. I'm learning LR3 at the moment and will see what can be done.
![]() | HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO |
MedicinSC Goldmember More info | Oct 13, 2011 22:56 | #1 I hope I have this sized correctly for posting. I know I should do something with her hair. I'm learning LR3 at the moment and will see what can be done.
Oct 15, 2011 20:05 | #2 Yeah... I don't know what I was thinking with that previous white balance. This one is cropped, white balanced for daylight and a few other miscellaneous changes. Better? Any suggestions or tips?
ChristopherStevenb Goldmember 3,547 posts Likes: 7 Joined Dec 2008 Location: Ottawa, Canada More info | Oct 15, 2011 21:00 | #3 Yeah, I'd say the crop helps. Haven't checked color balance by the numbers of either image but my eyes tell me I'd prefer something in between these two. The second might be more accurate by the numbers but just seems too cool, not as pleasing.
bob_r Goldmember More info | Oct 15, 2011 21:15 | #4 I believe the edit is too cool also. Here's my edit. What do you think? Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
Spike44 Goldmember 2,155 posts Likes: 3 Joined Dec 2007 More info | Oct 15, 2011 21:34 | #5 Sorry Kevin but I prefer the original uncropped but lightened a bit to bring out her eyes (I added a catchlight) - set white point and brighten the midtones a bit:
No reason to be sorry Spike, that's why I posted here. I do like yours better. What did you use to set the white point?
Titus213 Cream of the Crop More info | Oct 15, 2011 22:41 | #7 I like the original. The crop is OK and so is the color. Dave
winters19 Senior Member 262 posts Likes: 2 Joined May 2010 Location: Pierceton, Indiana More info | Oct 15, 2011 22:44 | #8 The first one is fine. The white balance matches the season. Canon 7D -Sigma 30mm F1.4 EX DC- -Canon 28mm F2.8- -Canon 50mm F1.8-
Spike44 Goldmember 2,155 posts Likes: 3 Joined Dec 2007 More info | Oct 16, 2011 09:12 | #9 MedicinSC wrote in post #13255750 No reason to be sorry Spike, that's why I posted here. I do like yours better. What did you use to set the white point? Thanks Christopher and Bob. I appreciate the input. I like your edit as well Bob, except that it looks like we're getting a bit bright on the arms. Now... I know there was a section about messy hair in that LR3 book....... ![]() I used levels -select the eye dropper for whites and clicked on the upper white flower to the left of the seam. I also moved the midtone slider a bit.
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | Oct 16, 2011 22:27 | #10 Definitely like the warmer color. Could cool it off if you want, but just a touch, not as much as the second one you posted. It makes her look to cold.
asay82 Member 162 posts Likes: 1 Joined Aug 2008 More info | Oct 17, 2011 15:08 | #11 why change something good? from the above, i like the first one better. sometimes, i find myself warming up few images after correcting WB. not accurate WB? so what if the picture looks better.
Oct 17, 2011 20:46 | #12 Thank you all for the comments and advice.... Seems I've had a g+ snafu and the first photo is gone. I'll see about getting it back when I get home tomorrow.
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
