Thread started 14 Oct 2011 (Friday) 09:54
Coloring a Grey BackDrop and Vignette
Peacefield
Oct 14, 2011 09:54 |  #1
I have a few scenic backdrops and would like to invest in a more traditional mottled muslin with a hotspot or vignette. I've seen posts here from others who will use a grey backdrop and then color it with a strobe and gels and would like to try this.
Since I'm still only experimenting at this stage, I'd like to keep the backdrop cost down and am searching eBay. Nearly always, the grey backdrops I see there have a consistent mottling; there's no hotspot or vignetting. I'm wondering, though, if this isn't something I'd create with the background light anyway? And if so, does the color of the gel carry out to the darker edges of the vignette?
Any insights will be appreciated.
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
Curtis ­ N
Master Flasher
Oct 14, 2011 11:03 |  #2
Here's a thread for ya.
https://photography-on-the.net/forum/showthre​ad.php?t=415671
The key to getting saturated color is to use a dark background. Light grey won't cut it. A light background will pickup light from the main & fill lights and the color will get washed out. With a dark background you will need more flash power under the gel, but that's the idea - you need to overpower the the main & fill lights without blowing it out.
In order to create a vignette you'll need to use some kind of snoot or grid on the flash. You won't get much noticeable color in the corners where the light doesn't hit it.
Be careful with those gels. They pickup a lot of heat. Make sure there's a bit of air space between the gel and the flash lens.
Wilt
Oct 14, 2011 11:25 |  #3
A very good example of what can be done with a BLACK background
https://photography-on-the.net …hp?p=4485524&po​stcount=23
And a great comparison of the use of white vs. black background
https://photography-on-the.net …hp?p=9492981&po​stcount=13
And black vs grey vs white
https://photography-on-the.net …php?p=3261798&p​ostcount=7
Peacefield
Oct 14, 2011 11:36 |  #4
You guys are great; thanks!
Peacefield
Oct 14, 2011 12:46 |  #5
Let me ask the question a different way. It seemed like all of the discourse in that thread involved seamless which can have a reflective quality to it. Will this same concept work with muslin which is not reflective at all?
John ­ Schell
Oct 14, 2011 12:47 |  #6
Great links.. How would you go about gelling for a full body shot?
Website (external link) || Instagram (external link)
TMR ­ Design
Joined Feb 2006
Oct 14, 2011 12:55 |  #7
Peacefield wrote in post #13250877 (external link)
Muslin is still going to reflect light. Almost any surface that's not black with reflect light.
The darker the color, the more light it will absorb. Yes, knitted or woven fabrics will 'leak' more light but they're still going to reflect it.
Robert
2,830 views & 0 likes for this thread, 5 members have posted to it.
1592 guests, 137 members online
