Thread started 16 May 2003 (Friday) 13:23
Shaky Camera photsop correction?
relux
Joined Apr 2003
May 16, 2003 13:23 |  #1
Hello all, please do not shoot me down that much ;) I am new to digital photography, just got a S50 and am learning quickly. I am having a camera shake problem when taking nightclub shots, I have no tripod. I am wondering if there is anything I can do to correct this picture?
http://www.probsd.net/​~relux/XS/requestforfi​x.jpg (external link)
Also, is there a procedure you follow for all the pictures after you get them on computer? Such as sharpening, etc?
I own Photosohp 6.
Thanks much!
Chad
eland
Joined Mar 2002
May 16, 2003 20:10 |  #2
Chad
Well in the poor light you are doing well.
A tripod or even a monopod would help.
I'm not familiar with your camera. If it allows you to set ISO, set it as high as you can. eg 400 or higher.
For the web, you need to cut down the size of the image
called Resampling to around 450 Kb.
Do this on a duplicate image not your original.
Image/Duplicate
Basic tools you would use if required are
Image/ adjust/ Contrast & Brightness,
Maybe Auto levels. maybe color saturation.
Have a play around. Its not difficult.
Usually some sharpening is needed.
For overall sharpening
Filter/Sharpen/ Unsharp mask.
Too much makes the image break down.
Experiment and undo if necessary.
Start with eg Amount 80+
Radius 0.4
Threshold 0
Use the amount slider and watch the effect.
Finally go to File......Save for Web.
Cut the quality down to usually between 40 and 60.
This makes your image load faster.
Drop in quality is not noticed.
Regards
eland
pappy
Joined Mar 2003
May 16, 2003 22:28 |  #3
Hi Chad - following eland's suggestions this was redone in Photoshop Elements 2 - levels and USM at 100, Radius 1.0, Threshold 0
Regards,
Peter
pappy
Joined Mar 2003
May 18, 2003 15:00 |  #4
Another rendition using the High Pass filter method for sharpening as found here http://www.luminous-landscape.com …igh-pass-sharpening.shtml (external link)
Regards,
Peter
eland
Joined Mar 2002
May 18, 2003 20:35 |  #5
Very well done Peter.
You are really getting places.
It's a lot of fun........... and addictive
Kind regards
eland
pappy
Joined Mar 2003
May 18, 2003 23:31 |  #6
Thanks eland....I have so much to learn but you're right, it is fun and addictive. It's when I see posts like 'Computer Magic' that I realize taking the picture is only a small part of the product.
Regards,
Peter
2,210 views & 0 likes for this thread, 3 members have posted to it.
1264 guests, 127 members online
