I have calibrated my monitor with an L* gamma setting.
When viewing my histogram on screen, is it advisable to set it to luminance,or,RGB?
Which will give me a more accurate histogram?
Thanks,
Mike
mike397 Member 165 posts Joined Dec 2006 More info | Oct 14, 2011 17:17 | #1 I have calibrated my monitor with an L* gamma setting. Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Oct 14, 2011 17:29 | #2 |
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 14, 2011 17:52 | #3 mike397 wrote in post #13251903 I have calibrated my monitor with an L* gamma setting. When viewing my histogram on screen, is it advisable to set it to luminance,or,RGB? Which will give me a more accurate histogram? Thanks, Mike There is no connection between monitor calibration Elie / אלי
So,...Your saying it doesn't matter what I choose in preferences..is that correct? Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 15, 2011 02:46 | #5 mike397 wrote in post #13252214 So,...Your saying it doesn't matter what I choose in preferences..is that correct? Mike Correct. Elie / אלי
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 15, 2011 03:31 | #6 BTW, although I have never calibrated to L*, I have read that it has a linear section in the lowest part of the curve (as does the sRGB TRC) which will reveal more shadow detail than 2.2 gamma, but can also cause posterizing in some LCD monitors. So you might want to watch out for this. Elie / אלי
Elie, Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
Mike, I've got a PA271w that gives me a "thrill up my leg" every time I use it...but ya still gotta balance your monitor with the printer. The things you do for yourself die with you, the things you do for others live forever.
Yes,I almost bought the 27in,but the price difference was too high. Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
The image that you linked to...what's with the hand, looks funny. The things you do for yourself die with you, the things you do for others live forever.
Looks ok on my monitor Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
| Latest registered member is bzguy 1369 guests, 182 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
