Thread started 15 Oct 2011 (Saturday) 09:06
Upgrading to CS5? What is up with 32 and 64 bit installations?
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Oct 15, 2011 09:06 |  #1
If I understand correctly, there are both 32 and 64 bit versions of CS5. My new computer will be running Win 7 Pro, 64 bit.
Is there any advantage to running one version or another of CS5? For example, is the 32 bit version limited on how much memory it can use, even though the OS sees 16 gig? And I make fairly regular use of my plug in library, especially NIK and Tiffen. Will a 32 bit plug in work in a 64 bit version of PS?
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
obkcaptain
Oct 15, 2011 10:58 |  #2
The first time I used CS5 under Mac 64 bits, I've found doesn't appear neither Lighting effects nor lens flare (filter>render) wich are in the 32 bits version....
I don't know if with Windows are the same.
Otherwise, you can imagine 32 or 64 bits as a team...the duty will be longer (in computer terms, of course) if you are using the smaller team.
A Canon gear, some lenses, mono(tri)pod, flash and need to learn...
hawkeye63
Joined Sep 2011
Oct 15, 2011 11:04 |  #3
"When running in 64-bit mode, Photoshop CS5 uses all the ram you can fit into your computer." http://kb2.adobe.com/c​ps/404/kb404901.html (external link)
I run CS5 on Windows 7 Pro 64 bit and all the filters are available, including Lighting Effects and Lens Flare.
solara
Oct 15, 2011 12:37 |  #4
The only reason for even installing the 32-bit version (you have the option of installing both the 32- and 64-bit version, or one or the other) is if you have older plugins that have not been updated to work with 64-bit CS5. Other than that, no reason to even install the 32-bit version and waste disk space.
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
René ­ Damkot
Oct 15, 2011 12:42 |  #5
obkcaptain wrote in post #13254196 (external link)
Then something else is going on.
Just checked. PSCS5, OSX 10.6.8 on a MacPro, 10Gb memory, 70% of which for PS.
Lens Flare was there.
Didn't check, but AFAIK Lightning effects works as well.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tkerr
Oct 15, 2011 13:26 |  #6
René Damkot wrote in post #13254447 (external link)
Availability of filters doesn't matter if you're using the 32 bit or 64 bit versions of CS5, what does make a difference is if your editing a image in 16 bit or 8 bit mode.
Lighting Effects is one that is only available for 8 bit images/documents.
Tim Kerr
F1, try it you'll like it.
René ­ Damkot
Oct 15, 2011 14:02 |  #7
Yeah, but lens flare works on 16bpc images in PSCS5…
tkerr
Oct 15, 2011 14:12 |  #8
René Damkot wrote in post #13254622 (external link)
Lens Flare does, But Lighting Effects doesn't.
Everything in gray isn't available in 16 bit mode.
In 8 bit mode everything is available.
I hope in future version of Photoshop CS* that all filters are available in 16 bit mode.
Tim Kerr
René ­ Damkot
Oct 15, 2011 14:42 |  #9
Ah. Waitaminute…
Seems obkcaptain is partly correct, and we are partly wrong :o
Checked here: Seems lighting effects is x32 only on OSX. weird.
From the comments here (external link):
There are no plans to update the aging Lighting Effects plug-in to 64bit. It’s like the Extract plug-in in CS4 which we replaced in CS5 with the new refine edge technology. We’re on the path to replace the Lighting Effects plug-in with something better in the future.
x32:
IMAGE: https://img.skitch.com/20111015-p4enihapkpx37uprqbd56xd6bs.jpg
x64:
IMAGE: https://img.skitch.com/20111015-nby3xr4qw9reyg1ftu558uhrsj.jpg
tkerr
Oct 15, 2011 15:02 |  #10
René Damkot wrote in post #13254709 (external link)
Ah. Waitaminute…
Ah, I see. I am using Windows 7 Pro.
Why would it be available for Windows and not OSX?
Tim Kerr
2,412 views & 0 likes for this thread, 6 members have posted to it.
1048 guests, 105 members online
