Thread started 18 Oct 2011 (Tuesday) 16:48
580ex color temperature
ajstonestreet
Joined Mar 2011
Oct 18, 2011 16:48 |  #1
Do the 580's have a consistent temperature throughout there power range? I know that some of the studio strobes can vary as much as 600 degrees
I have gear. Period.
dmourati
Oct 18, 2011 16:51 |  #2
I think the beginning portion of the impulse is bluer in color.
See, generally: http://blog.bronimagin​g.com …temperature-control-ectc/ (external link)
Curtis ­ N
Master Flasher
Oct 18, 2011 17:02 |  #3
I don't think it varies 600 degrees, but it does vary.
If you use AWB or Flash white balance setting on your camera, the 580EX II (not the original model) will report its color temp to the camera and the image will be recorded accordingly. You could take some shots in RAW mode at various power levels, open them with your RAW converter and see what the "as shot" color temp is.
PacAce
Joined Feb 2003
Oct 18, 2011 17:50 as a reply to  @ Curtis N's post |  #4
Here are the color temperature readings I just got from my 580EX II flash (three measurements per power level using a Sekonic color meter). As Curtis said, it does vary but not as much 600ยบ. The chart below also shows that the color temperature varies from shot to shot even for the same power level (less at the higher power levels than at the lower levels).
...Leo
mike_d
Oct 18, 2011 23:42 |  #5
I did a test a while back with my 580EX II and a WhiBal card. I varied the aperture to maintain the same exposure as the flash power changed. My results are below:
1/1 - 6100k (-2)
1/2 - 6300k
1/4 - 6400k
1/8 - 6450k
1/16 - 6400k (+2)
1/32 - 6500k (+3)
1/64 - 6500k (+2)
1/128 - 6600k (+4)
The number in ( ) is the green/magenta slider in Lightroom. A positive number indicates adding magenta to counter a green cast.
3,243 views & 0 likes for this thread, 5 members have posted to it.
1369 guests, 117 members online
