Does anyone here have experience with de-fishing a diagonal fisheye on a 5D2?
After cropping to a rectangle, how large an image are you left with? What aspect ratio is the image? And how wide is the remaining image?
Shadowblade Cream of the Crop More info | Oct 18, 2011 22:28 | #1 Does anyone here have experience with de-fishing a diagonal fisheye on a 5D2?
Oct 18, 2011 22:34 | #2 I've played with doing it in DxO and PTLens. I have a 5D and a Canon 15mm FE. If you completely de-fish an image, it looks like crap in my opinion unless you crop it so heavily you may as well have just used a much longer lens to begin with. Some light de-fishing can work nicely though.
Oct 18, 2011 23:57 | #3 For most landscape uses, I'd just need to correct the horizontals, not the verticals.
Oct 19, 2011 01:43 | #4 The more you de-fish it, the more stretched the corners get and corners aren't that great to begin with on the 15mm. I use my fisheye as a fisheye and have the 17-40 when I want lines to stay straight. I've done some landscape with the fisheye and depending on composition, it doesn't necessarily look like an obvious fisheye shot as long as I keep the horizon through the middle and there's nothing like a fence post near the edge.
rusty.jg Senior Member 855 posts Joined Mar 2009 Location: Cornwall, UK More info | I imagine that picture quality will suffer quite a bit. I have the Samyang 14mm (not a fisheye) and occasionally when I try to correct perspective distortion the sharpness of the image degrades quickly - the correction needed on a fisheye would be even greater. to be OR NOT to be = 1 (which is "to be" so that one's cleared up at last
Oct 19, 2011 04:33 | #6 rusty.jg wrote in post #13272341 I imagine that picture quality will suffer quite a bit. I have the Samyang 14mm (not a fisheye) and occasionally when I try to correct perspective distortion the sharpness of the image degrades quickly - the correction needed on a fisheye would be even greater. You could try stitching two UWA images together if you wanted a more normal looking image taken over a wide field of view? I do a fair bit of stitching already.
| Latest registered member is semonsters 1656 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
