Thread started 19 Oct 2011 (Wednesday) 23:42
Questions about Spyder 3 Calibration
chris ­ jones
Oct 19, 2011 23:42 |  #1
What is it about the Syper 3 Pro vs the Express that allows dual monitors to be calibrated?
Is it the sensor itself? I have a Dell laptop with a junk screen and I have it hooked up to an NEC231WMI for obvious reasons. I use this setup as an extended desktop, but really don't use much on the laptop screen.
Do I need to get the Pro model? What prevents me from calibrating each screen individually?
peanuthead
Oct 20, 2011 00:10 |  #2
Although the sensors look different between the 2 models, it's probably software limited.
Canon 6D | Canon 5D | Canon 24-70mm 2.8L | Canon 35mm 1.4L | Canon 85mm 1.8 | Canon 40mm 2.8
500px (external link)
tonylong
...winded
Gallery: 60 photos
Oct 20, 2011 01:14 |  #3
I don't know about the sensor but the package as a whole is different.
If you have Express, check with the company to see if they will update your software without needing another sensor. I don't know the answer.
Tony
chris ­ jones
Oct 20, 2011 01:30 |  #4
I should have been more clear.. I am looking to buy one of these kits.
Thanks for the help so far
WesternGuy
Oct 20, 2011 01:43 |  #5
chris jones wrote in post #13277326 (external link)
Are you looking to simply calibrate two monitors separately, or are you looking for a "studio match" that will calibrate the two monitors as closely as possible to the same "colour space"? Just asking...
WesternGuy
tonylong
...winded
Gallery: 60 photos
Oct 20, 2011 01:48 |  #6
chris jones wrote in post #13277657 (external link)
If you are looking to calibrate a dual monitor setup, then get the Pro version. The Express won't support it.
But you can use the Express on more than one system.
Tony
tonylong
...winded
Gallery: 60 photos
Oct 20, 2011 01:49 |  #7
And, it's the software and sensor together you need to use.
Tony
1,054 views & 0 likes for this thread, 4 members have posted to it.
Latest registered member is RawBytes
1351 guests, 160 members online
