I want to show a few examples that highlight the strengths and weaknesses of this lens, at least in my opinion.
Weakness:
Soft Corners even at conservative apertures. Moderate DOF/Corner to Corner Landscapes suffer.
This was at f8, take a look at the branches in the corners. A poor application of this lens is landscape type photos with details such as branches or other fine-textured objects in the corners, unless you aren't too worried about it. You can stop down to f11, maybe even f16, but diffraction will set in, and realistically f8 at 17mm will generally get everything into focus.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
Weakness:
Flare
This was probably right in the sweet spot for getting the worst flare, but the lens can flare when you get the sun in just the wrong spot. Not a huge deal breaker, but watch out for it.
Weakness:
Bokeh, Shallow DOF Photography, minimum focal distance
Well, obviously, f4 max aperture isn't exactly super wide. The minimum focal distance isn't the best, and you can see the bokeh isn't the smoothest of the canon lenses.
Strength: (same picture)
Unique perspective shots. The center sharpness is good, so if you want to highlight a central subject and let the softer corners be either OOF or just soft, to draw attention, then it will work very well:
Strength:
Central/near subject landscapes.
This neutralizes the effect of soft corners, the significant barrel distortion, and just works well.
Lastly, Weakness:
Barrel Distortion
If anyone ever thought the world was flat, they simply haven't seen a shot from the 17-40L
Aside from the bending of space and time, it holds true to the near-subject landscape strength though, not bad, just give it a little lens correction.
And possibly more importantly, Strength:
Price
For the price, good luck finding something as useable/versatile for a full frame camera within the scope of what a 17-40mm lens would be used for.
