Thread started 20 Oct 2011 (Thursday) 14:48
RAW conversion error in processing
garyeaton
Oct 20, 2011 14:48 |  #1
See attached a file with a processing error, what causes this? I use Breezebrowser Pro. Thanks for your help.
IMAGE: http://farm7.static.flickr.com/6019/6264084181_ca80045d4c_b.jpg
Gary Eaton www.garyeatonstudios.c​om (external link)
6D, 90D & XTi, Bogen tripods x2
135mm f/2 L, 100mm f/2.8 macro L, 24-105mm L, 50mm STM, 85mm f/1.8, Flash: Yongnuo 600RT x2 & Novatron Kits x5
50mm f/1.4, 17-40mm L, 70-300mm f/4.5-5.6 IS II, Sigma 150-600mm C
René ­ Damkot
Oct 20, 2011 15:11 |  #2
Corrupted raw file.
Could be caused by camera, card, transfer (reader or cable) or HDD.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
shazza
Oct 20, 2011 15:47 |  #3
We've just been experiencing the same thing with my husband's files. They seem to import fine, but then start "corrupting as you sit there and watch.
He was first loading his files to a USB 2.0 hard drive, then importing them into lightroom. When we skipped the USB external drive, and imported directly to the hard drive on the laptop, they are ok.
We also eliminated the card, and card reader as they both work fine with my laptop. In his case, the problem seems to have started after he upgraded to Lightroom 3.5 - not sure if this is significant.
Sharon
René ­ Damkot
Oct 20, 2011 15:51 |  #4
shazza wrote in post #13280733 (external link)
That's because LR shows you the built in preview first (which is not corrupted), then renders the actual raw (which is corrupt).
This does not mean the file isn't corrupted in transfer.
tonylong
...winded
Gallery: 60 photos
Oct 20, 2011 15:54 |  #5
Well, since the problems happen with the external drive and not with the laptop, then I'd look at the external drive and/or the associated connections rather than Lightroom. Yes, you can have problems with external "stuff".
You can troubleshoot, by replacing cables, changing ports, and lastly by trying a new hard drive. In the meantime make sure that you have backed up all of your images!
Tony
garyeaton
Oct 21, 2011 06:19 |  #6
thanks everyone
1,235 views & 0 likes for this thread, 4 members have posted to it.
1059 guests, 115 members online
