FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 23 Oct 2011 (Sunday) 13:53
Vignetting or crappy filter?
dexy101
Gallery: 93 photos
Oct 23, 2011 13:53 |  #1
Can anyone give me a bit of help, im not really bothered about the photo in question, just asking about the vignetting or if the polarising filter i used caused this? Come to think of it im struggling to remember if i had the filter on now, but i know the hood was on it.
5Dmk2 and 24-105
How can i prevent this in the future? It is 3 stacked shots.
IMAGE: http://img.photobucket.com/albums/v17/opelderek/IMG_3679_80_81_tonemapped.jpg
Mahgnillig
Joined May 2011
Oct 23, 2011 14:02 |  #2
I have this happen occasionally when I stack two filters (polarizer + 6-stop ND) at the widest angles, so that could be it. I just have to zoom in a little bit tighter and it goes away. The only other time I had this happen was when I bought a cheapo petal shaped lens hood and the hood was too big. I replaced it with a smaller hood and that solved the problem. I would zoom out to 24mm on your lens and check for interference from both the filter and the hood.
dexy101
Gallery: 93 photos
Oct 23, 2011 14:07 |  #3
Yeah its the first time it has happened, i can eliminate the hood as i know its the one for the lens and its always on correctly. I guess ill just have to go out again and replicate it but like you say just zoom in a tad, at least ill know what to look for now.
Thanks Jen.
bfreas
Joined Jan 2005
Oct 24, 2011 10:25 |  #4
Very likely that the polarizer was affecting the edges of the shot and not the center.
J-Blake
Great Googley Moogley!
Gallery: 129 photos
Best ofs: 9
Oct 24, 2011 10:51 |  #5
Each of the items you mention are easily tested and will determine which is the culprit better than us guessing.
I own the same lens and use it on my 1DsII which is also a full frame camera and don't recall ever having vignette issues with that lens. Most of my landscapes I use an original version 16 - 35 and always have vignetting when shooting at 16mm. I keep a UV filter on at all times (on both) and I'm sure that is not helping.
Jon
So much to learn, so little time.
A few worthy shots (external link)
tmcman
Oct 25, 2011 00:01 |  #6
Polarizers have different effects depending on the angle relative to the sun.
More effect shooting at right angles to the sun.
WA lenses have such a range of angles that they do produce different levels of sky darkening in different areas of the sky, in my experience.
Just a thought.
Comments, Questions, Observations Welcome
Fuji X-T2, 18-55mm, Gitzo 1541 w/ Markins M10 ballhead.
"Art always shows itself by doing much with few and simple things." Arthur Wesley Dow
Sgt.
Gallery: 56 photos
Oct 25, 2011 14:50 |  #7
The 24-105 tends to vignette a lot at 24 mm.
Iain
7D MKII
Another minion in the Pondrader fan club
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Oct 26, 2011 06:12 |  #8
Sgt. wrote in post #13305041 (external link)
Agree. Even at f8. DPP does a good job of removing it, and with that lens/camera combo, the setting should already be set.
Website (external link) |
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Oct 28, 2011 14:36 |  #9
tmcman wrote in post #13301876 (external link)
Just a thought.
I agree. This looks very much like a polarizer effect. Notice that there is no darkening at the bottom corners.
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
2,038 views & 0 likes for this thread, 8 members have posted to it.
1467 guests, 131 members online
