Thread started 25 Oct 2011 (Tuesday) 01:08
More extensions, raynox or a TC for more magnification?
BorislavKostov
Joined Apr 2011
Oct 25, 2011 01:08 |  #1
Currently I'm using a Sigma 105/2.8 + 56 mm extensions. I get approx. 1.85:1 with my 40D. What will the magnification and working distance be if I mount: Raynox DCR250, 1.4x TC OR 2x TC? Which of these would cause least image quality loss? What I want is more magnification. Should I buy more extensions, Raynox or a TC? If I should go for a TC - which models should I preffer and which should I avoid? I'm starting to think about a TC, but I'm not sure if it should be 1.4x or 2x.
Macro photography articles (external link) @ My Blog (external link) | FB Page (external link) | DeviantArt (external link) | Flickr (external link) | 500px (external link) | Artflakes (external link)
LordV
Oct 25, 2011 01:30 |  #2
Tcs will give you exctly the multiplication factor on them when mounted next to the camera body.
ie 1.4Xtc would give 1.4* 1.85 = 2.6:1
The DCR-250 would add another .84 to the mag ie 2.7:1
Your current working distances would be the same with a TC mounted and shorter with a diopter added. Generally I would expect more IQ loss with a TC vs a quality diopter.
You might want to consider a more powerful diopter such as a RAynox MSN-202 or perhaps a reversed 50mm lens on the 105mm. A reversed 50mm lens will giveabout +2 to your mags ie around 2:1 at max focus, 3:1 at min focus with no ext tubes used.
Brian V.
Macro Hints and tips
BorislavKostov
Joined Apr 2011
Oct 25, 2011 01:53 |  #3
Thank you, LordV. Another think I wanted to ask - will there be any difference if I mount a TC after the body, then extensions or if the TC is between the body and the lens? I've tried reversing a 50/1.8 II in front of the Sigma but I'm not sure the results will be good enough. So the magnification with a 1.4 TC and a DCR 250 would be the same, but what will the working distance with the DCR be?
LordV
Oct 25, 2011 08:32 |  #4
BorislavKostov wrote in post #13302244 (external link)
I'd be suprised if the results of reversing a 50mm lens onto the 105 are not better than using a TC. I used to do exactly that.
For max mag a TC should always be mounted firat on the body - then ext tubes if present then the main lens then a diopter or reversed lens.
Fraid I don't know off hand what the working distance with the DCR-250 would be apart from guessing it as being around 2" in front of the lens. As commented the working distance with a TC will be the same as it would without it.
Brian V.
BorislavKostov
Joined Apr 2011
Oct 26, 2011 00:08 |  #5
Last night I've tried reversing the 50/1.8 in front of the Sigma 105, but the result was approx. 2.4x magnification at about 1-2 cm from the lens, which for me is useless. So I'm thinking again which would be better - the less magnification of a 1.4x TC or the more of the 2x, but eventually with more quality loss.
dicklaxt
Oct 26, 2011 12:09 as a reply to  @ BorislavKostov's post |  #6
I found that the 2x did not perform as well as the 1.4x when used in the conventional (non Macro) way.The image quality was really not good.
dick
ceriltheblade
Oct 27, 2011 06:19 |  #7
is it relevant for you to spend the money instead (or save the money) to get the MPE?
7D/5dIII
50 1.8 II, MP-E65, 85 II, 100 IS
8-15 FE, 10-22, 16-35 IS, 24-105, 70-200 f4IS, 100-400 ii, tamron 28-75 2.8
600 ex-rt, 055xproB/488rc2/Sirui k40x, kenko extens tubes
BorislavKostov
Joined Apr 2011
Oct 27, 2011 06:44 |  #8
I can't afford the MP-E, that's the problem. Do you think I don't dream about it? So I'm trying to find a cheaper and still useful solution for higher magnification macro. I'm currently waiting my Sigma APO 2x EX DG TC to arrive tomorow :)
ceriltheblade
Oct 27, 2011 06:54 |  #9
gotcha. sorry.
well, i think you got some good advice so far...and good luck with the 2X DG TC.
7D/5dIII
BorislavKostov
Joined Apr 2011
Nov 08, 2011 04:41 |  #10
I finally tested the new setup and I'm very satisfied of the results:
IMAGE: http://borislavkostov.files.wordpress.com/2011/11/img_1474.jpg?w=150&h=100
IMAGE LINK: http://borislavkostov.​files.wordpress.com/20​11/11/img_1474.jpg  (external link)
IMAGE: http://borislavkostov.files.wordpress.com/2011/11/img_1567-68-69.jpg?w=150&h=100
IMAGE LINK: http://borislavkostov.​files.wordpress.com/20​11/11/img_1567-68-69.jpg  (external link)
IMAGE: http://borislavkostov.files.wordpress.com/2011/11/img_1747.jpg?w=150&h=100
IMAGE LINK: http://borislavkostov.​files.wordpress.com/20​11/11/img_1747.jpg  (external link)
100% crop (external link) from the las one :)
4,270 views & 0 likes for this thread, 4 members have posted to it.
1175 guests, 182 members online
