Can anybody here please enlighten me to the AF capabilities of the 180L?
I find that it seems to have big problems with AF, when starting at the close focus end, from 48 cm up to about 66 cm when focusing at subjects slightly further to far away (actually, it can't focus at all). Similarly, the other way around it has big problems as well, i.e., set to infinity trying to focus on relatively close objects, although seemingly less so.
I've noticed it does ok when helped a little, and I have also noticed that it really blurs everything too far away or too close completely into oblivion (and a beautiful blur it is
). Obviously, this may well be the cause of this behaviour, but I just want to make sure.
I am aware of the fact that this is a specialist lens, and have a few specilaist lenses for macro anyway, IOW, I am really only trying to establish whether this is normal behaviour or not.
BTW, this behaviour doesn't seem to differ much from using it on 1D MkIII or on 5D MkII (slightly better on 1D MkIII), as all other lenses I have focus fine on both bodies, so it is either a flaw with my specific copy, or possibly a feature of the lens design.
I did read here and there, on this board and a few reviews, that it sometimes needs a helping hand, just trying to discover to what extent is considered normal in this regard.
P.S.: Just found it will AF when done in incremental steps just fine, be it very slowly... seems awkward.
Thank you very much in advance!
Kind regards, Wim
