Thread started 27 Oct 2011 (Thursday) 10:36
Crop factor question
kevlarrr
Oct 27, 2011 10:36 |  #1
Hello all, I need a clarification on a subject thats been bugging me for some time....its about crop factor/focal length/field of view.
I own a 7D and tring to decide what would be a good lens for shooting portraits and already posted a question in this thread.
Ive read several times that 50mm to 85mm is an "ideal" range for shooting portraits as it compliments the subject. I also understand that my 7D has a crop factor of 1.6 so a 30mm would be equivalent to 48mm, 50mm => 80mm, 85mm => 136 and so on. So if Im using a 7D+85mm, I would have to move further away from the subject if I wanted to get a similar picture as taken with a 5D+135mm.
My question is, will the image produced by 7D+85mm still be in the "ideal" portrait range or will it produce a flatter image same as a 5D+135mm produces? If the latter is right, I would need to get a 50mm to stay within the 50-85mm range right?
I know the "ideal" range is just a thumb rule and photographers have been taking awesome pictures with 200mm lenses as well.
I hope I was able to explain my question :)
Thanks,
Kevin
My Gear: Canon 7D, 70-200L f/2.8 IS II, 17-40 L f/4, 30 f/1.4, Flashpoint II 320m, 430EX II, YN-460 II, RF-602
mrbtd
Oct 27, 2011 10:42 |  #2
Short answer is slightly. The 85 1.8 is an excellent choice for portaits on a crop camera.
There are other factors (depth of field)
mrbtd
Oct 27, 2011 10:51 |  #3
This will help you determine the DOF http://www.dofmaster.c​om/doftable.html (external link).
You can change the body
Stir ­ Fry ­ A ­ Lot
Oct 27, 2011 11:24 as a reply to  @ mrbtd's post |  #4
It will give the same subject/background compression (this is different than DOF) that a 5D+85mm would have. The working distance will be equivalent to a 5D+135mm.
5D3 | 5Dc | 7D | Tok 16-28 | 24-105 | 17-55 | 70-200 f4 IS | Pancake 40 | Sigma 50 | 85 1.8 | Yongnuo 565EX | Demb Flash Bracket | DiffuseIt Bounce Card | Manfrotto 535 CF Tripod | 2x Yongnuo YN560s | 2x PBL Softbox Umbrellas | CyberSync Triggers | Epson R3000 | A very understanding wife
SkipD
Joined Dec 2002
Oct 27, 2011 11:50 |  #5
kevlarrr wrote in post #13314948 (external link)
You have apparently misunderstood what you've read, as focal length does not affect the perspective of an image (which is what can "compliment" the subject or not). Perspective in an image is controlled by only one thing - the distance between the camera and various elements of the scene.
Please read our "sticky" (found in the General Photography Talk forum) tutorial titled Perspective Control in Images - Focal Length or Distance?.
For most portrait work it's best to keep at least six to ten feet between the camera and the portrait subject. The choice of focal length should be based on the desired framing of the subject when you've chosen the distance. The reason for the distance suggested is to keep the sizes of the nose and ears of the subject looking properly balanced. If you get too close (as suggested in our perspective article), the nose will, very likely, look too large.
Your understanding of what is "equivalent" seems to be flawed as well. There is no reference to another camera format in your writing. A 50 mm lens attached to your 7D will provide precisely the same field (angle) of view as an 80 mm lens attached to a so-called "full-frame" camera (a 35 mm film camera or a DSLR such as a 5D).
Please read and try to fully understand the following writeup about the "crop factor" which I've published a few times. I think it may help you out.
The "crop factor" is a reference number that relates to the difference in film or sensor size (known as the camera's "format") between two cameras like the Canon 7D and a 35 mm film (or a so-called "full-frame" digital) camera. Let me list the facts:
35 mm film cameras and so-called "full frame" DSLRs have a film frame or sensor size of approximately 24 mm X 36 mm, while the Canon 7D has an APS-C sized sensor, measuring approximately 14.9 mm X 22.3 mm. The whole line of Canon APS-C format cameras - starting with the D30 in the year 2000 and progressing through all of the "digital Rebel" xxxD series, the xxD series, and today's 7D - all have sensors that are approximately the same size (± 0.2 mm).
When camera manufacturers started designing digital SLRs (DSLRs), they decided that the DSLR bodies should be about the same physical size and configuration as their 35 mm film SLRs. For that reason, they concluded that they could use the line of lenses they already had for their 35 mm SLRs on the new DSLRs.
All lenses designed for 35 mm film cameras project an image circle onto the film that covers a 24 mm X 36 mm rectangle. The 35 mm camera records the portion of that image circle that is defined by the opening behind the shutter for the film (24 mm X 36 mm in size). A digital SLR with an APS-C sized sensor only records the smaller area (approximately 14.9 mm X 22.3 mm) of the image circle projected by the same lens.
When you put a 100 mm lens on a 35 mm film camera and make a photograph, then put the same lens on a DSLR such as the Canon 7D and make a similar photograph - same subject, same position for the camera, and same focal length - and then enlarge both photographs to the same size print (4 X 6 inches, for example), it will appear as though the photo from the Canon 7D was taken with a longer lens. That is because the image recorded by the Canon 7D was of a SMALLER PORTION of the image circle projected by the lens - cropped, if you will - compared to the image recorded by the 35 mm camera.
The special lenses made by Canon for the 7D (and other Canon APS-C cameras starting with the 300D - the first Digital Rebel) are called the EF-S series. These project a smaller image circle, making the lenses less expensive to design and produce in wide-angle and extreme wide-angle formats. The EF-S lenses also project deeper into the camera than the EF specification allows (the "S" referring to "Short back focus), allowing for less expensive wide-angle lens designs. However, an EF-S lens set to 40 mm will produce the exact same image as an EF lens set to 40 mm if both lenses are used on the same APS-C format body and both lenses are focused at "infinity". Focal length is focal length, period.
Now to the primary point that I want to make: NOTHING about lens EVER CHANGES when you put it on different format cameras. Focal length never changes. Aperture range never changes. The only thing that would change is the apparent field of view, and that change is not a function of the lens but it is a function of the size of the sensor or film that will record the image.
The "crop factor" is NOTHING MORE than a REFERENCE between two camera formats that lets you compare the field of view of particular focal lengths between the two formats. For the photographer who started with an APS-C format DSLR and has never used a 35 mm format camera (at least enough to have developed a feel for what certain focal lengths provide him/her), the "crop factor" calculations can be completely forgotten for day-to-day lens selections. Only when comparing two camera formats is the "crop factor" useful.
The "crop factor" calculation for "35 mm equivalent focal length" has only one valid use. That is for comparing the field of view of lenses used on two different format cameras.
Here's one common example: Joe took a photo of Mount Rushmore with a 35 mm camera from a particular place using a 200 mm lens. You want to replicate that photo with your Canon 7D. What focal length do you need to do that from the same location that he took his photo? Divide the 200 mm by 1.6 and you get the answer - 125 mm.
Here's another popular example: Mary Sue has been using a Canon SX120 IS point-n-shoot camera and is wanting to use a Canon 50D DSLR. She is, of course, interested in what focal lengths she would need to keep the versatility of the SX120 camera's 10X super-zoom lens. The SX120 lens is actually a 6.0 mm to 60.0 mm lens, but the advertising also shows the "35 mm equivalent" focal length range as 36 mm to 360 mm. To know the focal lengths needed for the 50D, merely divide the "35 mm equivalent" values by 1.6. In other words, Mary Sue would need 22.5 mm on the short end and 225 mm on the long end for the 50D to have the same field (angle) of view coverage as her SX120 IS camera.
The "crop factor" (as related to using lenses essentially designed for 35 mm SLR cameras) is always given assuming that the 35 mm film format (24 mm X 36 mm) is the reference master. Something to realize, though, is that the 35 mm film format is not, never has been, and never will be the "master" format against which all other camera formats are referenced. It is simply the format of the cameras that have also evolved into today's commonly used digital SLRs.
Beginning photographers are often first confronted with the crop factor puzzle when choosing their first DSLR camera. Intuitively, "Full Frame" sounds better than "Cropped", as if one is getting a complete camera instead of a partial camera. There are very few really significant differences (other than features) between similar-generation cameras of different formats. The fact is that both format cameras can be used to make essentially identical images, though different focal lengths will be needed on them to keep the framing the same.
Beginning photographers are also confronted with "crop factor" issues when buying lenses. Focal length (translated to how big or small of a field of view you want) is the first factor to consider when asking the “which lens?” question. The beginner doesn't have to convert every focal length to its "35 mm equivalent focal length" value but they should know that, on their APS-C camera, a 28 mm lens isn't going to be wide angle but instead is a "normal" focal length and that a 250 mm lens is going to be a rather long telephoto.
Many photographers who are new to DSLRs have acquired some very wrong ideas about "crop factor" issues. For example, they sometimes expect the focal lengths of EF-S lenses to be different (as in the focal lengths being pre-converted for the "crop factor") than the focal lengths of EF lens. This is completely false, as all SLR lenses are marked with their actual focal lengths. In addition, many new photographers who use APS-C format DSLRs seem to have been fed with the idea that they need to employ the "crop factor" calculations whenever thinking about using lenses on their cameras. This is generally not necessary at all as I have outlined above.
Stir Fry A Lot wrote in post #13315215 (external link)
This is misinformation at its best.
Skip Douglas
kevlarrr
Oct 27, 2011 12:06 |  #6
^^^ This definitely helps put things into prespective (pun intended :D)
I actually meant exactly what you've said above, just that, I should have mentioned 48mm, 80mm etc on a ff body. My bad.
tkbslc
Oct 27, 2011 12:14 |  #7
Bottom line, I really like 50-80mm range on APS-C (your 7D) for portraits.
And while perspective is not a function of focal length, it just happens that the distances that short telephotos require one to stand to take normally framed portraits produces an excellent and flattering perspective. That's why they are so popular.
Taylor
EOS Rp | iPhone 11 Pro Max
kevlarrr
Oct 27, 2011 12:22 |  #8
tkbslc wrote in post #13315427 (external link)
Yeah Im mainly interested in picking up either the 50L or sigma 85 1.4 or canon 85 1.8
nikmar08
Oct 27, 2011 12:27 |  #9
There's not much to be added to Skip's post. Here's another illustration that might be of help.
http://www.stepheneast​wood.com …/lensdistortion​/index.htm (external link)
EDIT: These were taken with a "full frame" sensor camera.
____O
__( \ \_
((_)/ ((_)
Nikhil | Gear List & Market Feedback | Flickr (external link)
Support POTN by donating here: https://photography-on-the.net/forum/donate.p​hp
kevlarrr
Oct 27, 2011 12:38 |  #10
nikmar08 wrote in post #13315493 (external link)
Wow. I personally liked the pic taken at 135mm the best. Which means Canon 85mm 1.8 or Sigma 1.4 for me :)
Thanks for the link!
mrbtd wrote in post #13314981 (external link)
I now agree.:cool:
nikmar08
Oct 27, 2011 13:02 |  #11
Don't mean to play with words but I think the point of Skip's and Wilt's sticky is to look at it the other way round... that one needs to stand at particular distances to get a "normal" perspective and to frame portraits the "normal" way, the focal lengths required just happen to be in the short telephoto range!!
____O
__( \ \_
((_)/ ((_)
amfoto1
Oct 27, 2011 13:05 |  #12
Hi Kevin,
Lots of good feedback already on this....
Have you ever shot 35mm film or so-called "full frame" digital?
If not, forget all the stuff about conversion factors.
All you really need to know are how lens focal lengths perform on your particular camera. One really only needs to fool around with conversion factors when they are using multiple formats or have learned and gotten accustomed to using one format and are changing to another. (By the way, this is nothing new... It was an issue with film cameras too, when we were switching between large format, medium format, 35mm, half frame on 35mm, and possibly even cine cameras using 16 or 8mm film, or subminiature formats such as 110 and 126 film.)
If you've only ever used 1.6X or APS-C format, all you really need to know is....
On your camera, lenses in the range 8mm to about 15mm are ultra wide to very wide angle.
- Lenses from 16mm to 28mm are moderately to slightly wide.
- The 30mm to 35mm range serve as "standard" lenses.
- 50mm through around 135mm act as short to moderate telephotos.
- 150mm to 250mm are fairly powerful telephotos.
- Anything upwards of that might be considered a super telephoto.
What you have been told regarding portrait lenses for your camera is correct. 50mm and 85mm serve nicely as "traditional" portrait lenses on a 1.6X crop camera like yours. You just have to consider your available working distance and the shots you want to take. For example, you might find an 85mm too long if working in a small studio and wanting to take head & torso to full length portraits, or even shots of couples. The working distance might be too short for that, but it may be perfect for tighter candids and/or outdoor portraits.
As SkipD mentions, the first thing to consider with perspective distortions is your distance from the subject. Too close will end up distorting them pretty badly, making noses appear big and ears tiny in the most extreme examples. Too far away will also distort, a "flattening" effect that's a lot more subtle (and actually is considered desirable for some types of portraits, such as fashion photography). So the lens' focal length is then dictated by the framing you need to achieve, at the correct distance. Most of us end up with a small suite of lenses for portraiture, to meet different needs.
It just so happens that the 50mm to 85mm focal lengths work out well on a 7D (or any other so-called APS-C/1.6X or 1.5X camera)... putting the photographer about the right distance from the subject for typical portraits. Choose one or the other depending upon your particular needs... If you want to shoot more formal portraits, some full length, etc., you might select the 50mm. If you want to shoot more candid shots, often shoot outdoors and have plenty of working space, the 85mm might be a better choice for you.
Eventually you might end up with both. Alternatively, someone who wants to use just a single lens might look for something in between these focal lengths... such as the Tamron 60mm f2.0 that they call a "macro/portrait" lens.
Another thing to consider is the lens' max aperture. Often for portraits it's desireable to blur down the background... especially candid shots where you have little control over the background. About the best you can get is f2.8 with zooms... might be enough... or might not. A 50/1.4 potentially gives as much as an additional two stops, and an f1.8 lens offers as much as 1-1/3 additional stops... compared to an f2.8 zoom (an additional stop in each case, compared to an f4 zoom). You mention the 50/1.2L and that's certainly a great portrait lens... However do be aware that it's somewhat specialized and might not be as versatile as some "lesser" lenses... Not to mention that for the same money you could probably set yourself up with three "lesser" lenses that give almost as great image qualities, and a lot more shooting options (50/1.2L - $1200 approx. Meanwhle Canon 20/2.8, 28/1.8, 50/1.4, 85/1.8, 100/2 and Tamron 60/2.0 all sell for $350-500 apiece.)
There are times and places to use wider and longer lenses for portraiture. Keep in mind that the 50mm and 85mm are just "traditional" recommendations and why. But, for example, you might want to show some of the person's surroundings in a portrait... Sometimes called an "environmental portrait", this can call for a wider lens such as your 30mm or a 28mm or even a 20mm. You do have to be careful, though... don't get too close because of the exaggerations already mentioned.... also don't position the person too close to the edge of the image, because most wide lenses also have some anamorphic distortion at the edges and corners, that cause things to look "stretched" and/or "bent". It can be really bad with portraits... For example, someone can end up looking like Hellboy, with one arm larger than the other. Conversely, I already mentioined that longer lenses are sometimes used for a specific "look", just be sure to have plenty of working distance!
Often with wide lenses, zooms have more distortion effects than primes. So a wide prime might be a little "safer" to use for portraits... though you still have to be a bit careful.
Oct 27, 2011 13:46 |  #13
SkipD wrote in post #13315330 (external link)
:oops:
Wilt
Oct 27, 2011 13:48 |  #14
As SkipD has commented, the 'flatter image' is the result of shooting from a distance. An 7D with 85mm lens has exactly the same FOV as a FF camera with 135mm len. If you put both combinations at the same shooting position, the resulting images will capture the same area and both will exhibit the same degree of 'flatness'!
On FF you use 100mm at a shooting distance of 9' for head and shoulder portrait that captures an area of 2.1' x 3.1'; 100mm is an extrement common FL for portraiture in the studio. With APS-C you use 63mm at a shooting distance of 9' for head and shoulder portrait that captures an area of 2.1' x 3.1'.
kevlarrr
Oct 27, 2011 15:47 |  #15
Skip, Alan and Wilt - you guys totally helped me understand and clear my concepts! Alan's post, totally bw!
I'll take your advice and go for the 85mm 1.8 for now. Already have a 60mm but a 50 1.4 would be added in future if needed :)
Thanks all who took the time to help me out.
Kevin
3,209 views & 0 likes for this thread, 9 members have posted to it.
Latest registered member is ahmed0essam
1553 guests, 188 members online
