Thread started 30 Oct 2011 (Sunday) 12:22
Stacker Software
eaglesnest
Oct 30, 2011 12:22 |  #1
I download Trial Zerene Stacker software to try out. The result is good; but it is so slow. To analyze and process 1 image took 5-10 min. What did I do wrong? it's not the computer. I have no problem with other programs such as Photomatix, PtGui, Topaz etc. Is there any other stacker software besides Zerene? I would like to try and compare the processing time.
www.eaglesnestphotogra​phy.com (external link)
LordV
Oct 30, 2011 13:17 |  #2
eaglesnest wrote in post #13328641 (external link)
Stacking software does take some time to go through the images depending on how many and how large they are.
Another one to try is helicon focus.
Brian V.
Macro Hints and tips
Martin ­ G.
Oct 30, 2011 18:30 as a reply to  @ LordV's post |  #3
5 minutes is not very slow, as Brian pointed out, it can sometimes take some time. 10 minutes could be, if you are trying to stack only a few images, but it would not be slow if you are going for a deep stack of a high amount of frames.
I was under the impression that Zerene is on the "fast" side as far as stacking goes. I do not think changing program will make a difference.
Not sure if that would make a difference, but I think you can decide how much memory of your computer you let Zerene use. Maybe that might be a problem if the allocated memory is too small?
How many images were you trying to stack?
Martin
6D & 70D
EF 24-105 L, EF 40mm, EF 85mm f1.8, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
eaglesnest
Oct 30, 2011 19:10 |  #4
Martin G. wrote in post #13329754 (external link)
Martin
Hi Martin,
How can I check what's the allocated memory given to Zerene?
I try to stack between 6-15 images.
What I mean by taking 5-8 minutes for analyzing and processing is for 1 image only, and not for the whole stack.
Martin ­ G.
Oct 30, 2011 19:53 as a reply to  @ eaglesnest's post |  #5
go in "preferences" and than "memory usage", mine is set 4605 megabytes allocated for Zerene.
yes, it would appear long, I thought you meant for the whole stack.
not sure if it will make a difference, but try to modify this setting first and see what it does.
Martin
6D & 70D
eaglesnest
Oct 31, 2011 06:58 |  #6
Martin G. wrote in post #13330016 (external link)
Martin
* Does it mean that you have 4 Gigs RAM on your computer? I only have 2 Gigs. That might be the reason.
I tried to stack using CS5, but the result is rather poor compare to Zerene.
Martin ­ G.
Oct 31, 2011 11:40 as a reply to  @ eaglesnest's post |  #7
I have 6 gig in total
Maybe e-mail Rik, the designer of the program, he would be the best person to answer your questions and if it would actually make a difference. He is very helpful and always take time to help.
Martin
6D & 70D
rjlittlefield
Nov 11, 2011 10:25 as a reply to  @ Martin G.'s post |  #8
Just to close out this problem and maybe help future readers...
The slowness was due to excessive paging caused by a memory management issue. Basically the user's computer had less physical memory free for use than is typical with 2 GB installed. The problem was straightforward to fix by adjusting the Zerene Stacker settings at Options > Preferences > Memory Usage.
Martin, thanks for the suggestion to contact me. That's always good advice when people see odd behavior with Zerene Stacker. I can't monitor all the forums where ZS is discussed, but I do respond promptly and thoroughly to any issues that I find out about. Email sent to upport@zerenesystems.c​om (external link) always comes to my personal attention.
Best regards,
Rik Littlefield
Zerene Systems
fotoray
Joined Nov 2011
Nov 22, 2011 12:05 |  #9
Suggest trying Helicon Focus.
Canon 5D MkIII | 7D | 20D | EF-S 10-22 | EF 17-40L | EF-S 17-85 | EF 24-105L | EF 70-300 DO | EF-S 60mm macro | EF 100L macro | 580EX II | RRS Series 2 tripod | plus many gadgets |
2,987 views & 0 likes for this thread, 5 members have posted to it.
Stacker Software
1071 guests, 186 members online
