Thread started 11 Apr 2001 (Wednesday) 21:31
ZoomBrowser & Attributes?
Curby
Joined Mar 2001
Apr 11, 2001 21:31 |  #1
Ok, here's the deal:
In Zoombrowser I highlight a thumbnail then right click and select show attributes then click > in the dialogue box.
How come when I do this I only get the following information about my picture?
Image Size
2048 x 1536
File Size
1042 KB
Drive Mode
Self-Timer Operation
I thought I was suppose to get all of that great information about my shutter speed F stop settings focal length etc. Where do you get all of that information I see posted with other peoples pictures? I have been at this for some time and have not figured this out yet. What am I doing wrong? I would like that info so I can share it with my image posts.
Thanks in advance for any input.
______
Curby
rknol
Joined Apr 2001
Apr 11, 2001 23:50 |  #2
Which camera do you use?
nahau
Joined Mar 2001
Apr 12, 2001 00:29 |  #3
Hi Curby,
What's going on with your zoombrowser?? You're supposed to get all the info...shutter speed, iso, flash, etc,etc!! Did you break it or something?? ;-)a
Maybe you need to reinstall. :-(
nahau
Rick
Joined Apr 2001
Apr 12, 2001 00:35 |  #4
Using version 2.6.0.11 I get the following output in a new window with a scrollbar when selecting the ">"
Camera Model Name
Canon PowerShot Pro90 IS
Shooting Date/Time
3/22/2001 9:50:58 PM
Shooting Mode
Program AE
Tv (Shutter Speed)
1"
Av (Aperture Value)
2.8
Metering Mode
Center-weighted averaging
Exposure Compensation
0
ISO Speed
50
Lens
7.0 - 70.0 mm
Focal Length
7.0 mm
Digital Zoom
None
Image Stabilizer
On
Image Size
1856 x 1392
Image Quality
RAW
Flash
Off
White Balance
Auto
AF Mode
Continuous
Parameters
Contrast Normal
Sharpness Normal
Color Saturation Normal
File Size
2004 KB
Serial Number
1020233
Drive Mode
Single-frame shooting
Macro
Off
Owner's Name
Rick Unland
Go to the Help/about and let us know what version of Zoom Browser you have and what camera you are using. Also in the help/about it also says what version of the canon camera support library is installed, I have 3.6.0.5
Best Regards
Rick
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Apr 12, 2001 04:15 |  #5
You'll get only this info from Zoombrowser converted TIFF's and BMP's. Zoombrowser does not pass all EXIF to converted images, only god and Canon knows why not...
Try CRW or JPG (from the camera), do you get the full info now?
Image Size
2048 x 1536
File Size
1042 KB
Drive Mode
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
Curby
Joined Mar 2001
Apr 12, 2001 07:20 |  #6
Thanks Pekka,
This was the first time I tried to do this and yes I attempted to get the info from a converted .tiff as well as a .jpg converted from .tif in ACDSee. The .crw before converting does give me this info. I guess I should learn to save my .crw files longer instead of deleting them so quickly.
_____
Curby
Image Size
2048 x 1536
File Size
1042 KB
Drive Mode
Pekka
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Apr 12, 2001 08:05 |  #7
Yes, save the CRW's! I consider them to be my negatives. All other images derived from them don't matter that much, but the CRW is the most important file to backup, as it contains the original data.
Oystein
Joined May 2001
May 23, 2001 15:04 |  #8
When I try to take backups of my CRWs, the Zoombrowser cannot take them back in the tree on the left. What am I doing wrong ?
Pekka
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
May 23, 2001 15:16 |  #9
Zoombrowser does not like write-protected CRW's (from CD-R. It accepts drag&drop, which is the easiest way to get pics in (but thumbnail creation is way too slow).
The easiest (and fastest) workflow for RAW's is currently in my opinion:
1. Download the files from the camera with Chris' Downloader (downloads THM's, too), create folders by daily subject as needed.
2. Drop the downloaded folder on Yarc shortcut (set it to extract JPG's only)
3. Check JPG's in any viewer (ACDSee)
4. Use TWAIN desktop module to convert those good shots to TIFF, or use Yarc. Set up a directory for "good photos"
5. Backup whole download directory to CD-R (files in the directory are JPG, THM, CRW, LOG and TXT). Backup "good photos" folder.
3,818 views & 0 likes for this thread, 6 members have posted to it.
1052 guests, 104 members online
