The lower section of my Bogen Monopod Model 3016 is slipping even when the clamp is fully closed. Is there any way to tighten it? Thanks.
BottomBracket Cream of the Crop 6,398 posts Likes: 1 Joined Dec 2004 Location: NYC More info | Nov 06, 2005 07:36 | #1 The lower section of my Bogen Monopod Model 3016 is slipping even when the clamp is fully closed. Is there any way to tighten it? Thanks. Pio
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Nov 06, 2005 08:04 | #2 I don't see the 3016 in the on-line catalog, but I will assume that it has the typical clamps like on my 680B. You should have a little plastic wrench (that clips to the monopod) that was supplied with the monopod. If you don't, an ordinary 8mm socket wrench or nut driver will suffice. Anyhow - what you want to do is to tighten the nut in the clamp (with the clamp open) a little bit and try it. Don't over-tighten it, however. Adjust it when the clamp is open and then make sure that it closes normally. If you have to really push hard to close the clamp, you've over-tightened it. Skip Douglas
BottomBracket THREAD STARTER Cream of the Crop 6,398 posts Likes: 1 Joined Dec 2004 Location: NYC More info | Nov 06, 2005 15:37 | #3 Thanks Skip - this is an old monopod of mine and I can't remember if it came with a wrench. If it did it is long gone anyway. Looking at the locking mechanism, it doesn't look like there is a place where a socket wrench can attach to, it looks more like a pin than a bolt. It hink I will take it to a photo shop here, maybe they know what to do with it. The good news is, I used it today (at the NYC Marathon) and it slips just to the point where I exactly need it to be, then it's snug. It may be that something is wrong with the shaft itself than the clamp. Anyway it still works for me, and I'll worry about it more when the slippage is worse. Pio
| Latest registered member is Thunderstream 1218 guests, 124 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
