Thread started 02 Nov 2011 (Wednesday) 17:03
Shoot mode question.
MrJack787
Nov 02, 2011 17:03 |  #1
What mode should I be in? I have tried taking simple practice sky shots in my backyard and I have found that a 30 sec exposure at 800 ISO and f/5.6 in blub mode and the same specs in av mode render me completely different results. In bulb it seems to gather a lot more light than in av. Is there something I am missing?
EOS 5D Mark II - EF 70-200mm f/2.8L IS II USM - EF 50mm f/1.4 USM - EF 40mm f/2.8 STM - Speedlite 600EX-RT - Alien Bees B800 x2
www.bendawsonphotograp​hy.com (external link)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Nov 02, 2011 17:14 |  #2
Bulb mode means that the shutter will stay open as long as you are fully depressing the shutter release button...so, if you push it and let up, your shutter will be really short; if you push and hold, your shutter will be really long (until you let up). In Av mode, the camera sets the shutter speed, so you're not actually getting a 30s exposure there. That's why the Bulb shot is gathering more light; the shutter is open a lot longer.
MrJack787
Nov 02, 2011 17:19 |  #3
By specs being the same I mean everything was exactly the same including a 30 sec exposure.
Celestron
Nov 02, 2011 17:43 |  #4
In Bulb you are totally in control of all settings as where in AV mode you only control a portion and the rest is AUTO . SO even tho you say the same specs the camera settings in AV mode will still have some different settings as the Bulb mode . Best way to tell is bring up the Histogram and see what the ISO , F/Stop and Exposure time is compared to your Bulb settings .
Snydremark
Gallery: 66 photos
Nov 02, 2011 17:48 |  #5
You can't specify f-stop AND shutter speed in Av mode; nor can you set a specific shutter speed in Bulb mode. So, how are you going about setting the "exact same" settings in both modes to do the comparison?
MrJack787
Nov 02, 2011 18:27 |  #6
Oh hmm then it must not have been a 30 sec expo in av. I guess I was lying :p Anyways what mode should I be in? Or does it not matter as long as I can get a 30 sec exposure?
Snydremark
Gallery: 66 photos
Nov 02, 2011 18:43 |  #7
Use whichever mode is easiest to shoot in with the settings you are trying to get. If your primary concern is getting a 30 second shutter speed, Tv or M are going to be your "go to" modes; you can specify 30s in either one. In Tv, the camera will adjust the aperture for you (which may/may not actually give you what you're looking for right off the bat) and in M you also have to specify your own aperture, but you need to understand what the meter is showing you in order to choose the right one.
the ­ jimmy
Nov 02, 2011 19:21 |  #8
Snydremark wrote in post #13344678 (external link)
Yes, also given the fact that the OP is shooting "sky" shots then having the aperture wide open seems to be the best option.
In manual mode choose your 30" shutter, then aperture and ISO, take some shots and adjust if required.
MrJack787
Nov 02, 2011 20:08 |  #9
Thank you guys! I will try your suggestions tonight!
SteveInNZ
Nov 02, 2011 23:00 |  #10
You may not have been lying. If it's really dark in Av mode, the camera would have selected the longest shutter time it has available, which would be 30 sec (it can't do bulb by itself). Try it with the lens cap on.
If the camera comes up with something less than 30sec, cover the viewfinder with your thumb.
"Treat every photon with respect" - David Malin.
Celestron
Nov 03, 2011 07:40 |  #11
MrJack787 wrote in post #13345004 (external link)
Since your testing sometimes when i shoot horizon night shots i'll use the "No-Flash" setting in the "Auto-Mode" side . It's exposes as long as it needs to pick up a certain amount of light without using a flash . You'll be surprised what quality of images you'll get !!
archer1960
Gallery: 6 photos
Nov 03, 2011 14:22 |  #12
I just always shoot manual, typically 15-30 sec depending on how bright my target is. Sometimes longer (60 - 120 sec) if I happened to get a good polar alignment on my mount. I control the camera with BackyardEOS (www.backyardeos.com (external link)).
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
MrJack787
Nov 03, 2011 17:40 |  #13
archer1960 wrote in post #13348873 (external link)
Thanks for your input. I just got the backyardEOS trial and it looks really cool. Is there a good tutorial out there for it?
archer1960
Gallery: 6 photos
Nov 03, 2011 18:59 |  #14
MrJack787 wrote in post #13349930 (external link)
I don't know; I haven't looked for one. It's fairly intuitive to get the basics going, and the author is very quick responding to questions on the yahoo group.
2,349 views & 0 likes for this thread, 6 members have posted to it.
1335 guests, 131 members online
