Ok, so the goal is to take a number of photos of the same view and stack them. Why not just take one photo and make "X" number of copies and then stack?
thejimmy Goldmember 1,426 posts Likes: 33 Joined Dec 2009 Location: west coast of Florida More info | Nov 03, 2011 17:42 | #1 Ok, so the goal is to take a number of photos of the same view and stack them. Why not just take one photo and make "X" number of copies and then stack?
Acamacho Senior Member 287 posts Likes: 10 Joined May 2008 Location: Danbury, CT More info | Nov 03, 2011 18:12 | #2 the jimmy wrote in post #13349946 Ok, so the goal is to take a number of photos of the same view and stack them. Why not just take one photo and make "X" number of copies and then stack? No silly questions, I'm curious of other's answers since I'm relatively a newbie as well. But my take.. Gear | Flickr
cyberon Senior Member 540 posts Likes: 3 Joined Jan 2010 Location: Perth, Australia More info | Nov 04, 2011 05:04 | #3 That is basically correct. Stacking the same image doesn't achieve anything! 500D, Speedlite 430EX II, Lens : 15-85mm; 50mm F1.8 II; 100mm F2.8L IS Macro; 70-200mm F4L; Samyang 8mm F3.5
trossite Member 129 posts Likes: 1 Joined Dec 2010 More info | Nov 13, 2011 10:35 | #4 I also have a newb question about stacking. From reading these threads people seem to use two different programs for stacking. Canon T2i, Canon EF-S 18-55mm IS, Tamron 70-300mm Di VC USD, Canon 35mm f/2
cyberon Senior Member 540 posts Likes: 3 Joined Jan 2010 Location: Perth, Australia More info | Nov 13, 2011 16:34 | #5 trossite wrote in post #13393416 I also have a newb question about stacking. From reading these threads people seem to use two different programs for stacking. DSS for bringing out lots of details / stars and another type of program for creating star trail pics. My question is if you take lets say 40 pics, can those be used both for the nice clean crisp photos in DSS and for creating star trail photos? This may be possible depending on the duration of the overall exposure but generally no. Images usually taken of constellation, dso, etc normally are tracking the stars and for this reason the foreground are usually excluded. 500D, Speedlite 430EX II, Lens : 15-85mm; 50mm F1.8 II; 100mm F2.8L IS Macro; 70-200mm F4L; Samyang 8mm F3.5
markweaver Senior Member 458 posts Likes: 3 Joined Aug 2010 Location: Fairfax VA More info | I believe that stacking also reduces sensor noise by analyzing all the shots and averaging them to reduce noise. Mark
trossite Member 129 posts Likes: 1 Joined Dec 2010 More info | Dec 05, 2011 11:52 | #7 Been constantly reading through the Astronomy and Celestial thread here and in the sharing section ever since i first looked about 4 weeks ago, I can't get enough. Canon T2i, Canon EF-S 18-55mm IS, Tamron 70-300mm Di VC USD, Canon 35mm f/2
Dec 05, 2011 12:40 | #8 If you're really desperate, you could try just laying your camera on its back and shooting that way. Anything that makes sure the camera is stable and gets the part of the sky you want to see is good enough. BTW, 30 sec will likely be too long for 18mm, so be ready to experiment and shorten your exposures if you get trailing (unless you want star trails, of course). Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
trossite Member 129 posts Likes: 1 Joined Dec 2010 More info | Dec 05, 2011 13:24 | #9 I think i really want to try some star trails pics using a star trails stacking program. Is there a recomended exposure length for doing that? Canon T2i, Canon EF-S 18-55mm IS, Tamron 70-300mm Di VC USD, Canon 35mm f/2
Dec 05, 2011 14:03 | #10 As long as you can get without making the sky too bright in the resulting exposure. You'll have to experiment to find that. Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
Dec 09, 2011 18:38 | #11 cyberon wrote in post #13394658 This may be possible depending on the duration of the overall exposure but generally no. Images usually taken of constellation, dso, etc normally are tracking the stars and for this reason the foreground are usually excluded. For star trails, you want to include some foreground to make your image interesting and the image is not tracked so that you can create the star trails. Image taken for star trail though can also be use for time lapse photography which you might also want to experiment. Actually yes you can use DSS to stack pictures taken with fixed tripod. Secret for above is fast/wide aperture, short exposure, and you need to keep your image close to center of the view so the stacking artifacts are not visible. (your field is not 100% flat, so as the DSO/sky moves across your fixed field of view it is slightly stretched at the edges of the lens, so try and avoid that) There is much you can do w/o a tracking scope, and learn the heavens above. Have fun. Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
A.S.I.G.N.Observatory ...For the future of mankind More info | Dec 12, 2011 22:46 | #12 the jimmy wrote in post #13349946 Ok, so the goal is to take a number of photos of the same view and stack them. Why not just take one photo and make "X" number of copies and then stack? The, "Signal" (real light) in each photograph (sub-exposure or sub) will be the same. The, "Noise" in each sub will be different. Stacking images improves the signal to noise ratio. Builds By Baz website http://www.buildsbybaz.com
| Latest registered member is semonsters 1522 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
