Thread started 04 Nov 2011 (Friday) 12:12
Shape of Umbrella Lights: Shoot Through or Reflective
Peacefield
Nov 04, 2011 12:12 |  #1
How different is the shape of light when shooting with an umbrella shoot-through vs reflective?
Anectdotally, I would think shoot-through would be much wider sending light everywhere. But when I think about bounce angles, I'm guessing a reflective umbrella would also send light pretty much just as wide, no?
Is a reflective umbrella more focused? Why would I want to use one over the other?
Thanks.
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
René ­ Damkot
Nov 04, 2011 12:22 |  #2
You can get a shoot through closer to your subject (umbrella shafts length) and the light is slightly different.
http://www.visatec.com …torials/light-comparison/ (external link)
(Compare the bottom two modifiers)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Tawcan
Joined Apr 2004
Nov 04, 2011 12:33 |  #3
When the 2 umbrellas are placed the same distance from the subject, a reflective umbrella will have more diffused, softer light where a shoot through would be a bit harsher. It's easier to get a shoot through closer to your subject without poking his/her eyes out. :D
boblai.com (external link) |Facebook Fanpage (external link) | Flickr (external link)
Wilt
Nov 04, 2011 12:40 |  #4
Tawcan wrote in post #13353676 (external link)
The examples from Bron/Visatec seem to be contrary to what you just stated. Look at
  • the shadow edges,
  • at the relative contrast of the face,
  • the relative contrast of shadows
  • the amount of illumination on the back of the chair
in the shots from 'umbrella white' vs. 'umbrella transparent'.
The reflective umbrella appears to have more 'pop', while the shadow areas are darker with the translucent umbrella. But the shadow edges on the background show that the translucent umbrella has more diffuse light than the reflective umbrella.
Tawcan
Joined Apr 2004
Nov 04, 2011 12:46 |  #5
True but that's assuming the distance from the umbrella to subject are exactly the same. If stand is placed at the exact same spot but the umbrellas are flipped around then obviously the shoot through will be a bit closer to the subject.
René ­ Damkot
Nov 04, 2011 12:50 |  #6
Wouldn't call it "harsher". No idea what to call it though.
Reflected light has a bit less "knack" then diffused IMO, all else being equal.
IMO a shoot through umbrella is more like a small, round, portable diffusion panel ;)
The fabric obviously has a big impact.
Wilt
Nov 04, 2011 12:50 |  #7
Tawcan wrote in post #13353730 (external link)
We are no longer comparing the modifier, we are also introducing relative size difference as well as the light falloff difference due to distance. Apples vs. oranges.
And that makes the closer source softer, while also increasing the degree of light falloff with distance
Peacefield
Nov 04, 2011 13:00 |  #8
Thanks, everyone.
I was mostly curious about the shape or cone of light. That link was very helpful, Rene. And I guess it confirms what I was thinking even though it seems a little counter-intuitive; that the reflective will spread light just as far if not father than a shoot through.
René ­ Damkot
Nov 04, 2011 13:06 |  #9
A shoot through also reflects light, but a reflective (with black backing) doesn't shoot through.
So, in a room with white walls, you might get a lot of bounce using a shoot through.
http://www.zarias.com …ough-umbrella-vs-softbox/ (external link)
Peacefield
Nov 04, 2011 17:48 |  #10
Another good resource; thanks again, Rene.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Nov 13, 2011 13:58 |  #11
Yes thanks Rene. Bookmarked that.
Image Editing OK
4,025 views & 0 likes for this thread, 5 members have posted to it.
1592 guests, 137 members online
