Thread started 05 Nov 2011 (Saturday) 10:19
Bag Advice
Diamond ­ Lil
Nov 05, 2011 10:19 |  #1
I carry the following gear in my current bag (Kata KT R-103 Digital Rucksack), and find it a bit tight. Domke bags look intriguing, but not being thoroughly familiar with what is out there I'm seeking your wisdom. Any input you might offer will be appreciated.
Canon EOS 50D - Ungripped
CanonEF-S 10-22mm f/3.5-4.5 USM
Canon EF-S 17-55 f/2.8 IS USM
Canon EF 70-200mm f/2.8L IS USM
Canon EF 100-400mm f4.5-5.6L IS USM
Speedlite 580EX II
MacBook Air (Dimensions: 12.8 in (325 mm) wide × 8.94 in (227 mm) deep × 0.16 in (4 mm) to 0.76 in (19 mm) high)
elogical
Nov 05, 2011 11:45 |  #2
It sounds like maybe a good case for the F-2 if you didn't need the macbook in there. I don't know exact dimensions on the macbook or anything but I think you'd be looking at the deeper messenger style ones to fit the computer and then I'm not sure if any of the messenger bags are actually big enough for all that.
I have a few domkes but I don't know the whole lineup as well as some so I'm sure someone else will chime in soon with how popular these bags are around here
Gear
Jon
Joined Jun 2004
Nov 05, 2011 15:00 |  #3
Gripped or ungripped body? I'd lean toward getting the Domke F-804 satchel, which has a couple of folder-type pockets, one in the front and one in the back. You could slip the MBA in there. Put a 720-230 insert in there for your "loose" lenses and let the 100-400 rest on its side (the lens hood for that is strangely large).
Jon
Cocker Spaniels
LuLuTheMonk
Joined Nov 2010
Nov 05, 2011 18:38 |  #4
F-Stop Loka with a Large ICU?
Canon 7D | Canon 70-200 f/2.8L IS II | Sigma 150-500 OS | Canon 24-105
Diamond ­ Lil
Nov 05, 2011 21:20 |  #5
elogical wrote in post #13357481 (external link)
Thank you. The macbook is almost always with me as I travel back and forth to work. If it did not fit in the camera bag it would mean having an extra bag which I'm trying to avoid. Is it safe to assume that if you have a few Domkes that you are satisfied with them?
Jon wrote in post #13358038 (external link)
Thank you. I like the idea of the folder-type pockets.
LuLuTheMonk wrote in post #13358647 (external link)
Thank you. First Google search does not lead to many sources for this bag in the States. Britain yes. Do you know a good source? - Never mind. I found them. Thank you.
Joris
Nov 06, 2011 13:46 as a reply to  @ Diamond Lil's post |  #6
Considering the weight of your gear, I'd recommend a backpack with a padded waistbelt, like the Lowepro Pro Runner 450 AW :).
elogical
Nov 06, 2011 19:35 |  #7
You definitely won't be disappointed with the domkes as long as you can find one that's the right size for what you expect for it, I think they're great.
The best part to me is that not every single side and pocket is padded so you can fit a lot more gear than other bags having the same exterior dimensions. And of course you can always use padded inserts for specific things that you do want to be padded.
The workmanship on domke bags is great as well. Fabric is really durable and stitching, etc is well done.
...so they're definitely not the only game in town but they are quite good.
Gear
Diamond ­ Lil
Nov 06, 2011 19:56 |  #8
Joris wrote in post #13361589 (external link)
Thank you. Truthfully I am using a backpack bag now and would love to change, but may end up with one again.
elogical wrote in post #13362921 (external link)
Thanks again. Since all sides of the bag are not padded do you recommend putting lenses in the cases they came with and then in the bag?
Jon
Joined Jun 2004
Nov 06, 2011 20:03 |  #9
Diamond Lil wrote in post #13363004 (external link)
Nope.
  1. Padding is over-rated as "protection"
  2. The outside pockets offer plenty of additional protection (which you don't really need)
My gear goes in the Domke inserts, nothing more. And I've been using Domkes since shortly after Bert Keppler first mentioned them (right after Jim Domke created the first one). Never changed. No reason to.
Jon
Cocker Spaniels
2mnycars
Nov 06, 2011 20:44 |  #10
I am a relatively new Domke bag owner. My first one was an F3/x rugged wear.
Deceptive bag. I don't have much gear now. I can carry my dslr with grip, 2 zoom lenses (1 mounted) and a flash. Easily with empty pockets. Package is light and easy to shoot from.
I traded a TT Retro 10 for a TT Speed Racer. It is heavy, comfortable and easy to shoot from.
The Domke is easier to shoot from. I am a slow learner! I keep buying bags that are heavier than they need to be, because of the padding used. It is hard to buy Domke here. Vendor's prices are insanely high; it's hard to figure out the bags the way they are labelled and displayed for sale. Inserts and pads? Forgetaboutit!
Jon's advice is gold!
Dave
Diamond ­ Lil
Nov 08, 2011 20:28 |  #11
Jon wrote in post #13363032 (external link)
Nope.
Thank you. Seeing so much support for Domke bags I began to question my newbie impression that padding was essential. Your insight is appreciated.
2mnycars wrote in post #13363271 (external link)
Thank you so much. I'm learning quickly that Jon's advice most certainly is gold.
2mnycars
Nov 08, 2011 20:34 |  #12
Thanks. Good gear helps us take better photos.
My Domke bags are Good Gear.
My Domke vest is eons old, and works as well as it did the first day I wore it. POTN vests hadn't even been thought of then. But they are a bargain! :-)
DaveL
Dave
Heath
Joined Sep 2009
Nov 08, 2011 20:35 |  #13
I am a slow learner! I keep buying bags ...
I laughed when I read this.
I have an F2, F3x, and F5xb. I keep buying other bags thinking I am going to find something better, and always go back to the Domke.
When am I going to learn.
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
2mnycars
Nov 08, 2011 21:11 |  #14
diputs, thanks! A kindred spirit. ;-)a
My Father used to say, "Too soon old. Too late smart." Bless him. R.I.P.
Dave
aquaticson
Joined Oct 2011
Nov 08, 2011 21:41 |  #15
Not to thread Jack or anything but I dont want to make a new thread when I need the same advice, from what I"m reading on here Domke bags are kinda the way to go. This may be beneficial for the OP as well, I'm looking into this bag:
http://www.tiffen.com …ame=domke&itemn​um=700-02A (external link)
It says it fits 2 pro dslr's and 4 to 6 lenses, does anyone have any actual experience with this bag and how much it can truly take because my gear list is going to be as follows:
Canon 550d
Canon 7d (potentially Gripped)
70-200 F2.8L IS II
24-70 F2.8L
Rokinon 8mm F3.5 Fisheye
Tokina 11-16 F2.8
50mm f1.8
Speedlight 580exii
Rode shotgun microphone
L.E.D Light
MISC. a/v cables and accessories (battery chargers, usb cables, etc.)
Will it fit?
Sway Heavy (external link)
Canon 550d - 24-70mmf2.8L - 50mmf1.8 - 75-300f4.5-5.6(sold) - Rokinon 8mm Fisheye - 18-55 kit lens - speedlite 580EXII
5,630 views & 0 likes for this thread, 12 members have posted to it.
Bag Advice
2495 guests, 97 members online
