Thread started 05 Nov 2011 (Saturday) 13:38
Photograph Lightning From an Airliner
RbnDave
Joined Feb 2002
Nov 05, 2011 13:38 |  #1
Hello All,
I have been working on a technique for photographing lightning at night from an airliner. I get a lot of practice -- I'm a pilot. Anyhow, I think I finally figured out a method that works and you should be able to pull this off from a window seat in the back of the plane.
The key is to understand that lightning acts like a strobe. It lasts for a split second and then it's done. In fact, it almost doesn't matter how long your shutter is open. The lightning will be fast enough to stop the action. It's like a giant second curtain flash.
IMAGE: http://www.pbase.com/skysaddle/image/138322107.jpg
So how exactly do you capture an image like this? Believe it or not this photo was taken with a 30 second shutter speed. Here's the settings f6.3 at 30 seconds and ISO 800. I set the focus to manual and set the focus distance to infinity (the sideways 8 on the focus scale). I then pointed my camera towards the weather and held it very steady while the shutter was open.
In the dead of night at high altitude there isn't much ambient light. The light source for this picture is 99% from the lightning. This means you need to use the same techniques as you'd use when you're shooting with flash/strobe. The brightness of the lightning in the finished photo depends on aperture and ISO. You have to chose between limited depth of field and image noise. If you happen to be flying really close to the bad weather you can use a lower ISO and smaller aperture. If the lightning is far away you have to open the aperture and up the ISO. I can't give you any hard guidelines, but a good starting point is ISO 800, f/5.6, and shutter open 30 seconds.
Why the long shutter speed? This gives you more chances to catch a bolt. Otherwise you're just guessing when lightning will strike and you end up with 200 pics of inky black nothing on your CF card.
IMAGE: http://www.pbase.com/skysaddle/image/138322144.jpg
So if 30 seconds is good, why not try going longer? Why not put the camera in bulb mode and leave the shutter open till something awesome happens. That's how I got the above shot. This one was taken at ISO 400 and f6.3. I held down the shutter button till a really big bolt flashed. Pretty cool. You can see some motion blur in this picture, but I think it makes the picture look that much cooler.
As far as getting to see lightning at night from an airliner... It's actually very common in the summer. If you live in the US and fly from the east coast to the west coast on a summer evening I can almost guarantee you'll see some lightning while you cross the great plains. You have to keep you're window shade up and don't fall asleep or you'll miss it. the best place to see lightning is in the southeast, along the gulf coast, and over Texas. If your flight takes you in these areas, be sure to have your camera accessible.
And for you nervous flyers... don't worry about thunderstorms. Modern aircraft have awesome radar and we navigate around the weather very easily these days. If you see lightning out the window don't worry. Your pilots are making sure to stay out of the rough stuff and will keep you safe. The size of the sky can be deceiving. The menacing weather you're seeing out your side window is probably 30 miles away.
If you like this sort of thing stop by my blog (external link). I post photos from my aerial adventures pretty regularly.
California Photographer (external link) -- My Photo Blog (external link) -- Free Photography Lessons (external link) -- Twitter (external link)
Naturalist
Adrift on a lonely vast sea
Nov 05, 2011 13:46 |  #2
Outstanding images and great little tutorial.
5D Mk IV & 7D Mk II
EF 16-35 f/4L EF 50 f/1.8 (Original) EF 24-105 f/4L EF 100 f/2.8L Macro EF 100-400 f/4.5-5.6L[/FONT]
hoser36
Nov 05, 2011 15:03 |  #3
absolutely amazing!!
5 D III, 5D, 1D mkIIn, 24-70L f2.8 II, 17-40L f4, 70-200L f2.8 IS II, Canon 85 f1.8, 600EX-RT x2, ST-E3-RT
www.gp-photography.ca (external link)
MD83driver
Nov 05, 2011 15:06 as a reply to  @ Naturalist's post |  #4
My timing is usually not that good, The big one usually hits right After the 30 second or 1 minute shutter closes and/or it is combining the exposures :-).
60D/EF 70-200mm f/2.8L IS USM/10-22mm/18-55mm/28-135mm/Sigma 150-500mm/Gripped/Sigma 1.4X extender /Lumix DMC-ZS40
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Nov 05, 2011 15:07 |  #5
That first image is utterly surreal.
500px (external link)
1x (external link)
instagram (external link)
sastein
Nov 05, 2011 19:21 |  #6
Who's flying the plane? :)
Interesting effect. How do you minimize the reflections off the windows if people around you have the reading lights on? No matter how close I get to the window, some reflection seems to sneak in.
As for safety, yeah it's pretty safe. Let me tell you about the time my flight from SFO to YVR got hit by freak lightning. I managed to see it hit the wing on my side of the plane before we dropped a few hundred feet. I think I know what zero G's feel like. I was sitting just behind the left wing and the hit was pretty spectacular.
Kodak Brownie, Instamatic, Hawkeye
Normal Boring Stuff (external link)
DaleP
Nov 05, 2011 19:33 |  #7
Brilliant stuff! Thanks for sharing the pics and info. :)
Mick ­ Emmett
Nov 06, 2011 17:04 |  #8
RbnDave wrote in post #13357804 (external link)
That's quite a worrying statement coming from a pilot :D Nice shots.
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Nov 07, 2011 04:40 |  #9
The only draw back while sitting in the passenger cabin is trying to minimize reflective glare from the lights inside the cabin. While one can smack the lens on the inner pane, the reflection from the outer pane still manages to get through unless you pull the window shutter down as long as you can and then try to cover the rest with a blanket. :D
Julian
altitude604
Nov 07, 2011 05:31 |  #10
very cool shots!
definitely going to give that a go next time there's something red on the WX radar. ;)
Erik - Three Miles Final (external link)
- Gear List -
Mike
ugly when I'm sober
Gallery: 51 photos
Nov 07, 2011 05:37 |  #11
sastein wrote in post #13358784 (external link)
IMAGE: http://www.travelsnitch.org/wp-content/uploads/2010/10/TS_airplane_autopilot.jpg
:p
OP - great tutorial and great photos. I'm having a look at your blog for more :)
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
Mike
ugly when I'm sober
Gallery: 51 photos
Nov 07, 2011 11:36 |  #12
Well, been through your blog and found it very enjoyable and very interesting. I heartily recommend it to all :)
Gear
UK South Easterners
highergr0und
Joined Aug 2011
Nov 07, 2011 11:51 |  #13
Nice blog..... so where are the to be continued pics from area 51?
T3i, Sigma 10-20, Sigma 30 1.4, 18-55 kit, 55-250, YN-565, a few books, some software, and a desire to get good.....
ChasWG
Nov 07, 2011 23:34 |  #14
Cool stuff! The first image is really very impressive.
Chas Gordon
7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8
http://www.flickr.com/​photos/chaswg/ (external link)
http://vimeo.com/user9​461302/videos (external link)
britain
Gallery: 280 photos
Joined Jun 2005
Nov 07, 2011 23:43 |  #15
Thanks for posting just awsome! Great pictures on your blog also!
7D2, 20D , 100-400L I, 100-400L II, EFS 17-85 , EFS 18-135, EFS 10-18mm, 100 2.8 macro , ring light, 430EX II, PD Capture Pro, Lifted modified Jeep to shake it all up:)
My Website HERE (external link)
4,015 views & 0 likes for this thread, 17 members have posted to it.
1060 guests, 103 members online
