Thread started 06 Nov 2011 (Sunday) 07:37
New 27" monitor
chenga732
Nov 06, 2011 07:37 |  #1
Hi all,
Currently, I have a Asus 24". I am looking for an upgrade to a 27". I looked at the Apple LED Cinema Display 27" and the colors look superb. Of course, it will not work on a PC. Can anyone tell me what is the next closet monitor that will have similar output?
cheers
Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
chauncey
Nov 06, 2011 08:06 |  #2
I have this one and love it. > http://www.necdisplay.​com …%20-monitors/pa271w-bk-sv (external link)
mike397
Nov 06, 2011 08:54 |  #3
+1 on Chauncey's recommendation ,I almost bought this model,but ended up with the PA231.
http://www.necdisplay.​com …op-monitors?Refurbished=1 (external link)
Please note,it is a refurb.
Mike
Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
http://mike397x.zenfol​io.com/ (external link)
chenga732
Nov 06, 2011 09:52 as a reply to  @ chauncey's post |  #4
thanks for the info. How is the NEC compared to the dell u2711 or the HP 2740?
lowrider
Nov 06, 2011 10:55 as a reply to  @ chenga732's post |  #5
Why do you say the Apple Cinema Display won't work on a PC? It has a Mini Display Port and if your PC has an MDP output on the video card, it will work just fine. I have a Mac Pro with a flashed Gigabyte AMD HD6870 Graphics Card with an MDP and an HP ZR24w display with a Display Port. I am using a Mini Display Port to Display Port Cable and it works just. An Apple Display is really just like any other display, although the input ports are limited to MDP or Apple's new Thunderbolt port, which is backward compatible to MDP.
Personally I don't like the Glossy Screen that Apple uses, but to each his own. IMO, HP makes beautiful displays. It appears that HP has recently updated it's IPS Monitor Line Up and now has a 27" Display, model ZR2740w, here:
http://h10010.www1.hp.​com …2270-3884471-5163694.html (external link)
But as with all non-Apple monitors it is a matt screen.
Lou
chauncey
Nov 06, 2011 12:32 as a reply to  @ lowrider's post |  #6
Check the warranty on NEC
chenga732
Nov 06, 2011 13:40 |  #7
lowrider wrote in post #13360928 (external link)
Lou
thanks. I was told by the Apple store staff that it will not work. I will look into the HP monitor as well.
Tony-S
Nov 06, 2011 20:08 |  #8
Unless Apple has changed the display's firmware then it probably won't work on non-Apple hardware. There was a lot of hackintoshers who tried workarounds, but no one could find them.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
lowrider
Nov 06, 2011 21:44 as a reply to  @ Tony-S's post |  #9
^^^^See this thread:
http://store.apple.com …9KY9P4PKUKADUKX​C2KH7JPYKT (external link)
If the PC has an MDP or if you have a Display Port to MDP cable or a DVI to MDP cable it will work as stated in the thread.
Oh, BTW, I believe all PC HD6870 graphics cards have MDP Ports. As I indicated above, I am using an HD6870 PC card in my Mac and it has 2 MDPs.
Lou
chenga732
Nov 07, 2011 18:53 as a reply to  @ lowrider's post |  #10
lowrider, thanks for the info. It looks like the old 27" monitor will work but does not mention about the new 27" thunderbolt connection.
lowrider
Nov 08, 2011 09:06 as a reply to  @ chenga732's post |  #11
^^^^I've done some reading since I posted, and it appears you're right, the new Thunderbolt display doesn't play nice with MDP. However, from what I have learned last years MDP display and the Thunderbolt display seem to have the same panel and construction, and last years model is still available. Sorry for the misinformation:o
Lou
newporthomie
Nov 12, 2011 17:09 |  #12
look at dell.com - they have an awesome 27", I'm pleased with mine
fotocrack
Nov 12, 2011 23:37 |  #13
I purchased a Planar PX2710MW 27-inch Widescreen Flat Panel LCD Monitor from Dell. I paid $245 after taxes. Should be getting it on Monday.Will let you know once I try it.
I found a coupon on fatwallet. You can set up an alert and you will get a notification once the deal is back.
Link here to the old deal (external link)
5DM3 lover :cool: //My custom build computer //My Feedback
PLEASE DONATE TO YOUR LOCAL FOOD BANKS AND LOCAL CHARITIES
lowrider
Nov 13, 2011 11:20 as a reply to  @ fotocrack's post |  #14
^^^^Looks like a nice monitor, but the monitors we have been discussing are all IPS technology. The monitor you bought is TFT, TN technology. While TFT, TN mat be good, it's not really in the same league with an IPS, IMHO. Also the resolution is 1920 X 1080, which is the same as the standard 24" wide Screens. So you don't get more information than a 24" or even a 23" with the same resolution, you just get a larger picture with the same information.
All the reviews on that monitor seem to be good, so you appear to have made a good choice.
Lou
René ­ Damkot
Nov 13, 2011 14:34 |  #15
IPS is also TFT: http://en.wikipedia.or​g/wiki/TFT_LCD (external link) ;)
But I think the PX2710MW is a TN screen (2ms response time)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
4,532 views & 0 likes for this thread, 9 members have posted to it.
New 27" monitor
1505 guests, 137 members online
