Thread started 06 Nov 2011 (Sunday) 18:23
ACR tweaks not as strong in PS CS4
BV1DMKIIn
Nov 06, 2011 18:23 |  #1
A weekend ago I thought some of my RAW tweaks were not as strong as I made them, but it was getting late and I shrugged it off. While working on a new batch of photos converting RAW to jpg in ACR, I could tell for a fact that my ACR tweaks were not being preserved 100% when the file is sent to PS CS4. Attached you can see the same image open in CS4 and Bridge that shows the stronger tweaks. (Bridge is on the right).
Is there anything to do to make PS CS4 receive(?) the full changes made in ACR? It's like CS4 is showing maybe 50-70% of the tweaks' intensities. I typically boost the Saturation from 0 to 9-13 and the Blacks from a default of 5 up to 8-10. Over and over I see where my changes are not transferring over completely when the file opens in PS.
Any help is appreciated.
1DMKIIn, 5DMKIII, 20D, 50 mm f/1.8, 10-22 EF-S, 28-135IS, 28-75 f/2.8 Tamron, 70-200 f/2.8L IS, 100-1400L, 24-105L, 580EXII
René ­ Damkot
Nov 07, 2011 09:43 |  #2
Compare images in different viewers at 1:1 view. The difference in sharpness is probably caused because you are at "fit to screen"
Check your PS color settings.
www.getcolormanaged.co​m/color-management/pscolorsett​ings/ (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
BV1DMKIIn
Nov 07, 2011 20:26 |  #3
Thanks! It turned out Bridge was defaulting to Adobe RGB Colorspace, and PS was in sRGB.
1,087 views & 0 likes for this thread, 2 members have posted to it.
Latest registered member is EBiffany
1599 guests, 98 members online
