Thread started 07 Nov 2011 (Monday) 19:55
ISO setting in 40D for good results
LudwigVB
Joined Nov 2010
Nov 07, 2011 19:55 |  #1
With my 40D I have not really noticed any difference in picture quality between 100, 200 and 400 ISO. I therefore tend to set it to 400 ISO for almost all situations (unless I need it to be even faster). I appreciate the benefit of being able to use faster shutter speeds, so as to minimize the effects of camera shake and subject movement, which might result in a wasted shot at lower speeds. Does anyone else feel that way? Am I missing something by not utilizing ISO 100-200?
Overread
Gallery: 12 photos
Nov 07, 2011 20:15 |  #2
It honestly depends a lot upon what you shoot and the conditions you're shooting in.
People shooting in studios with fully controlled lighting will likely never want to leave the cameras base ISO value; whilst those shooting action, sports, wildlife might well be pushing 400, 800 or higher depending on the lighting, to ensure that they get a good enough shutter speed.
Myself I'd say use an ISO as high as your comfortable with as a starting point and then review you settings - increase the ISO if needed, but also if you're getting crazy fast shutter speeds (for example) in a situation that does not call for them then by all means slip the ISO down a notch.
Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Tamron 24-70mm f2.4, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
My flickr (external link)
LudwigVB
Joined Nov 2010
Nov 08, 2011 00:31 |  #3
Thanks for that. Actually, I can think of a couple of cases where ISO would need to be lowered: first, when needing slow shutter speeds to blur movement (typical example is for a waterfall); second, to have a shutter speed low enough to use flash fill in harsh sunlight at midday, causing deep shadows under people's noses and chins.
Stickman
Nov 08, 2011 01:24 |  #4
If you can't tell the difference, its good enough for your needs.
Stick
http://www.flickr.com/​photos/stickgunner/ (external link)
bohdank
Nov 08, 2011 06:44 |  #5
What he said.
DStanic
Nov 08, 2011 06:56 |  #6
I don't think twice about using 400, If i go outside I usually turn it down to 200 and go from there. The 40D is great up to 1600 and 3200 is there if you need to get the shot.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
899 views & 0 likes for this thread
Latest registered member is OverTheHill
696 guests, 274 members online
