Thread started 07 Nov 2005 (Monday) 01:34
Are coloured filters any use?
DimensionZero
Nov 07, 2005 01:34 |  #1
So I did a search and couldn't find any info or comments on using coloured filters on a dSLR...
I'm thinking about getting a Yellow and a Red (and if I understand correctly, to bring out the blue skies and sunsets respectively) along with a circular polarizer..
Any thoughts on this?
Also, has anyone heard of Quantaray? Yey or nay?
Thanks guys!
Ken
Canon 7D
Sigma 10-20mm f4-5.6 EX DC | Tamron 28-75mm f2.8 XR Di | Canon 50mm f1.8 | Manfrotto 3021BN w/486RC2
deviantArt (external link) | my Blog (external link)
SkipD
Joined Dec 2002
Nov 07, 2005 06:00 |  #2
There is not a single reason that I can think of to use colored filters on a DSLR. Colored filters are used to change contrast between various elements of the subject when shooting with black and white film. You can do everything in software now, and to a much more controllable degree.
Don't even think of Quantaray (a "non-brand") for filters. Quantaray is a private-label name for Ritz Camera (and at least one other store name) and is applied to cheap stuff made by who-knows-who. That stuff may be acceptable for somebody who doesn't have a clue about photography, but nobody who cares about quality should even consider it.
Skip Douglas
ddelallata
Nov 07, 2005 06:27 |  #3
SkipD is right, but a good quality circular polarizer is a good investment.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
SkipD
Joined Dec 2002
Nov 07, 2005 06:34 as a reply to  @ ddelallata's post |  #4
I overlooked the polarizer in the original post - that is definitely something I would recommend, but a good quality one for sure (multicoated is a definite requirement).
Skip Douglas
GSHodg
Nov 07, 2005 06:40 as a reply to  @ SkipD's post |  #5
Definately should have a circular polariser.
I still use Graduated neutral density filters too to help especially landscapes - to balance bright skies and darker ground areas. What do poeple think about ND filters nowadays?? Could/Should I be doing that in PS?
Gordon
www.gordonhodgkinson.c​om (external link)
20D, CS3, Epson 2400...still learning how to drive it all! :D
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Nov 07, 2005 06:59 as a reply to  @ GSHodg's post |  #6
The effect from circular polarizers can't be duplicated in PS. ND grads can be done by "cheating" such as taking multiple exposures and blending them. (http://www.luminous-landscape.com …s/blended_expos​ures.shtml (external link)) and this may even be desired when there's an uneven border between the light & dark parts of the scene. Pure ND filters - when one wants longer shutter speeds - also can't be duplicated in PS. A CPL will add a couple stops and a smaller aperture will add more stops, but these may not be desired or might not be enough.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
DimensionZero
Nov 07, 2005 14:18 |  #7
ah... thanks everyone, this has helped me greatly!!
A friend of mine was going to check out Ritz Camera so I figured I might pick up a few things, but since it seems I don't need the coloured filters, I'll just get a circular polarizer from a store up here.
Thanks again! :)
Ken
Canon 7D
SkipD
Joined Dec 2002
Nov 07, 2005 18:14 as a reply to  @ DimensionZero's post |  #8
Thanks again! :)
DON'T go to Ritz to get the filters. Their stuff (Quantaray) is, shall we say, less than stellar. Get a good name brand such as Hoya (there are others, but that's my favorite).
Skip Douglas
neil_r
Cream of the Proverbial Crop
Joined Jan 2003
Nov 07, 2005 18:18 as a reply to  @ SkipD's post |  #9
I used to use yellow and red filters, but that was only when using Black and White film (do you remember that stuff).
N
Neil - © NHR Photography
lostdoggy
King Duffus
Joined Aug 2004
Nov 07, 2005 18:48 as a reply to  @ SkipD's post |  #10
Actually the high end Quantaray is made by hoya for Quantaray denoted w/ DMC it is equivalent to the HOYA HMC. If you ever get a chance to go to a Ritz store you'll see the filter demo w/ 3 Dimes just like Hoya's. They also have Quantaray by Cokin as well. Ritz also carrys Sunpak Filters. If you check out the site you'll see that one of the filter is made by Marumi Japan.
I'm fortunate enough to have Adorama & B&H near me that I can get practicly any filter brand I want.
DimensionZero
Nov 08, 2005 12:49 |  #11
hmm, this also brings up another point.
I don't remember where I found it, but there was a site that compared all the different brands of poloarizers and stuff and I seemed to have lost it.
Does anyone here have it? Or maybe something similar?
I'm curious how much difference there is between the major brands.
Thanks!
Ken
Canon 7D
Scottes
Joined Nov 2003
Nov 09, 2005 05:31 |  #12
This isn't a comparison of filter brands, but I wrote this in response to someone else asking if brand matters:
The reasons to buy good filters are pretty much the same as the reasons to buy good glass:
Good filters are neutral in color and won't add a color cast to your picture.
Good filters are well-shaped or more perfectly flat. They won't add distortions to your pictures.
Good filters have coatings that will allow more light to pass through, and/or reduce reflections. They will greatly lessen the chances of flare or glare or reflections in your final image. (Note, look for Multi-Coated lenses. Considering the same brand and size the more money you pay just about always goes toward the coatings, and every coating has a purpose. All of those purposes are geared towards lessening the bad light and increasing the quality of good light that hits your sensor/film.)
Good filters have better things about their build. Perhaps thicker frames, perhaps better threads, better knurling, perhaps better anti-reflective paint. (I recently had to get a step-up ring and B&H and Adorama were out of the $7 General Brand rings I normally buy. I went local and had to buy a $20 B&W ring. It was quite a difference from the Generals in all the above points.)
Good filters clean more easily. Last week I spent an hour cleaning 4 Hoya lenses, cursing and swearing the whole time because I could not get them clean. I tried 3 different cleaning solutions, 2 different wipes, 2 different microfiber cloths. I went to the camera store and bought $37 worth of cleaning supplies - all different - in order to find the best way to clean my lenses and filter. Well today I saw a message stating that Hoyas are notoriously difficult to clean, and B&W is better. I don't know if that's completely true, yet, but my next filter will be a B&W.
The more you pay the better the coatings, the better the frame, the better the glass, the better the anti-reflective paint, the better the knurling, the better the light and less glare, flare, and reflections.
So buy the best you can afford.
DimensionZero
Nov 09, 2005 14:13 |  #13
Thanks Scottes, that was very helpful!
Ken
Canon 7D
4,983 views & 0 likes for this thread, 7 members have posted to it.
1571 guests, 116 members online
