Thread started 08 Nov 2011 (Tuesday) 16:27
"Extending" the edges of an image to allow for a canvas wrapround
nigpd
Nov 08, 2011 16:27 |  #1
I have an image that I want to put to canvas, but the edge of the subject of the image is a bit too close to the edge of the current print.
I therfore want to "extend" the edges of the image to create additional image area to allow for a wrapround for the canvas and hence keep the subject well within frame as it would be for a straight print - if that makes sense. I have created a canvas size to allow for the wrapround which is 1½" each side and top and bottom. In effect, its a border that needs filling with the edges of the image.
My question is, what is the most effective way of creating a fill in of this border in Photoshop CS4 to provide a wrapround?
thanks in advance for your help
My flickr (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Nov 08, 2011 16:31 |  #2
Easy, just make a new blank canvas the size you want to create. Paste the existing image into that blank canvas leaving the edge area, or at least the problematic edge blank. The you can clone existing image area into the blank for fill, or fill it with color if you like. It doesnt have to be perfect because of the wrap.
JakAHearts
Nov 08, 2011 17:24 |  #3
Can you post the image?
Shane
nigpd
Nov 09, 2011 03:10 |  #4
JakAHearts wrote in post #13372571 (external link)
Sure can........
IMAGE: http://farm6.static.flickr.com/5092/5723246745_4e8f742de3_b.jpg
Edsport
Nov 09, 2011 06:04 |  #5
You could use the clone brush to extend the photo...
Cameras - Canon 350D, 5D
Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
Flashes - Yongnuo YN460 II, YN468
RF-602 transmitter and 2 receivers
Wallace ­ River
Gallery: 167 photos
Nov 09, 2011 06:10 as a reply to  @ Edsport's post |  #6
.....or you could buy "Perfect Resize 7". It has a neat one-click type of application for exactly that purpose. It has several ways of extending the original, by stretching, mirroring, and at your choice of opacities. Plus it's a very useful piece of software on it's own for its primary purpose.
My Flickr (external link).
Merlin_AZ
Nov 09, 2011 07:44 |  #7
Extend the top using Content Aware Scale and a little cloning.
kirkt
Nov 09, 2011 08:25 |  #8
Genuine Fractals (now called "Perfect Resize") will do this automatically - however, all it does is reflect or stretch the edges of the image - that is, is does not create new content, it just reuses what is already there, which is fine because who is going to look around the edges of the wrap?
For each edge:
1) select a few inches of the edge and copy it.
2) paste it as a new layer and then Edit > Transform > Flip ... either horizontal or vertical, depending upon which edge you are treating.
3) Once all four edges have been done, extend your canvas to the required size.
4) move each piece into place.
See attached. Genuine fractals also has provisions to blur the edge between the original image and the flipped extension, but it just looks sloppy.
kirk
ps - it looks like you made some sort of funky edit along the left edge of the image, like you copied and pasted part of the original to "clone in" more image on the left - you left a hard edge that is even more apparent when you do what I just outlined above.
Kirk
René ­ Damkot
Nov 09, 2011 09:23 |  #9
Yep.
https://photography-on-the.net/forum/showthre​ad.php?t=795419
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,711 views & 0 likes for this thread, 8 members have posted to it.
954 guests, 108 members online
