Thread started 09 Nov 2011 (Wednesday) 13:21
Just bought a 60D, first lens recommendations?
Ady2glude707
Joined Jun 2011
Nov 09, 2011 13:21 |  #1
I mainly shoot family pictures (two year old mostly) indoors or when were out and about (camping, pumpkin patch, birthday parties etc).
Canon EF 50mm f/1.8 II?
Canon EF 50mm f1.4 USM?
I want to buy the 24-105 L lens down the road and upgrade to FF eventually.
Keyan
Joined Mar 2011
Nov 09, 2011 13:28 |  #2
Did you get any kind of lens kit?
I have the 50 1.4, it works well on the 60D.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
CactusJuice
Nov 09, 2011 13:40 |  #3
The Canon 10-22mm. It will act like a traditional 35mm at the long end but also give you awesome horizontal reach indoors. Very fun, and sharp, lens.
BrickR
Joined Mar 2011
Nov 09, 2011 13:55 |  #4
I'm a fan of the Tam 28-75 as a general lens on crops, not to mention it works on FFs. The 17-50s you'll find with image stabilization are crop body lenses (just FYI). If you know you'll want the 24-105 just save up and get it. I assume you have a kit lens in the meantime.
My junk
The grass isn't greener on the other side, it's green where you water it.
Ady2glude707
Joined Jun 2011
Nov 09, 2011 13:56 |  #5
Keyan wrote in post #13376542 (external link)
Yup, got a 70-300 and 55-250, but I dont think I'll be needing them and going to sell ???
Vixen89
Nov 09, 2011 14:13 |  #6
Sigma 17-70 2.8 OS. :o
I'm actively lazy!! :D | Gear List | photovxn.com (under construction)external link
mckinleypics
Nov 09, 2011 14:15 |  #7
Exciting!!!!
The 50 1.4 is a blast. Although, admittedly, it hasn't seen any use since I got my 24-70.
Dave
7D, 70-200mm 2.8 L IS, 24-70mm 2.8 L, 50mm 1.4, Tokina 11-16mm 2.8, 580EXII
My Flickr (external link)
iLvision
Joined Oct 2011
Nov 09, 2011 14:34 |  #8
I think you should just get a 17-55mm and one good prime for portraits. When I first bought a 60D, that’s all I had. Later on, my kit consisted of a Tokina 11-16mm, 35L and a 135L. I had to get rid of my “Crop” lenses later on when I got a 5Dmkii. So If I were you, decide whether you will need a FF in the future or not, otherwise there are some good glass for your 60D Crop sensor. I learned my lesson not to get any Third-Party lenses; I only shoot with L-Series now :)
Ilya | Gear | flickr (external link) D800| 14-300mm f/1.4GL ED VR III USWM
amfoto1
Nov 09, 2011 14:40 |  #9
Out walking around - camping, pumpkin patch, b-day parties (outdoors) etc. - Consider picking up a Canon EF 28-135 locally off Craigslist. It's a nice walk-around lens for little money: fast accurate USM, close focusing, and IS. Around here there are usually two or three available on Craigslist for about $200. The reason it's cheap is that a ton have been sold and the market is pretty flooded with them... It was offered as kit lens on 40D and 50D for a few years. But it's not really what you'd call a "kit lens"... it's midgrade build quality and is capable of quite good image quality.There are more than a few pros using the 28-135 instead of the 24-105L (which costs 3X to 5X as much, but is better sealed against dust, has better IS, is sharper at the tele end, however vignettes more heavily at the wide end). 135mm is long enough for a lot of things, though it's best to stop down the 28-135 a little at the most tele end of the zoom (it's a wee bit soft). And, 28mm is merely a "standard" lens width on a crop camera like 60D... So you might want to pair it up with a wider lens (see below).
Canon is now commonly bundling the EF-S 18-135 with 60D... It seems a decent lens, too... We certainly are seeing a lot of good shots being done with it... It's nice that it's 10mm wider than the 28-135... but it is EF-S and it lacks USM. It sells new for about the same as the 28-135, adds about $100 more in the kit than the 28-135 did, and is relatively new so the used prices on it are still about $400.
Another popular standard lens is the EF-S 15-85mm. It's quite compact and covers a nice range for a walk-around lens on a crop sensor camera. And it's capable of very nice images. However, by the time I were spending what this lens costs, I'd be looking for one with an f2.8 aperture (instead of f3.5-5.6), even if it costs a little more. It's EF-S, so also not usable on full frame.
Arguably the "best" standard zoom for your camera is the Canon EF-S 17-55/2.8. IQ is top notch. However, it is rather pricey and "only" covers 17-55 range. f2.8 is always nice to have on a standard zoom, though. Not usable on full frame, though.
I hear a lot of good things about the Tamron 17-50/2.8 non-VC... Affordable and quite sharp. Again, there's limited range and it's not usable on full frame cameras.
Some also like the Sigma 17-50/2.8. It's a bit more expensive though, and another "crop only" lens.
To compliment a "walk-around" or standard zoom, you might want a wider lens such as the Canon 10-22 (if you have plenty of money... it's about $850 new, rarely under $650 used) or Tokina 12-24/4 (new about $550, used around $400). I think those are the two "best value" UWA lenses. There are also Sigma 8-16mm and 10-20 (2 different versions now), Tokina 11-16/2.8, and Tamron 10-24 to consider. The wide lens you choose might be influenced by the standard or "walk-around" lens you have chosen. For example, a 12-24 might match up nicely with a 28-135, or an 8-16 with a 17-55... but an 8-16mm would leave a big gap in some key focal lengths used with a 24-70, 24-105, or 28-135.
If you shoot a lot of portraits, a 50mm would be a nice lens to have. The Canon f1.8 is cheap at about $120 ($150 with the optional hood, if you want it)... capable of decent images, but pretty plasticky and has slower, less accurate AF. The Canon f1.4 is better built and has somewhat nicer image quality (more flare resistant, better contrast, better color saturation, nicer background blur). It will cost $400 US by the time you get the lens hood (necessary with this lens, not mandatory on the f1.8 since it's front element is so recessed).
You don't seem interested in a longer lens, so I'm not going to get into those other than to say that you really don't have to look much farther than one of the four different Canon 70-200s. They are all top notch.
For sake of "full disclosure", personally I shoot both crop and full frame cameras, so my "basic" lens kit is:
- Canon 24-70/2.8 (for its f2.8, L sealing against dust and overall durability)
- Canon 28-135 as a backup/loaner lens, or sometimes as a convenient walk-around lens. (2nd or 3rd copy of this lens I've had, bought used but like new off Amazon for $250, incl. shipping, lens hood & a 72mm B+W filter).
- For wider angle: Tokina 12-24/4 on crop and Canon 20/2.8 prime on full frame.
- For longer telephoto: 70-200/2.8 IS and 300/4 IS
- "Portrait" primes, for their larger apertures: Canon 28/1.8 (mostly w/ crop), 50/1.4, 85/1.8 and 135/2 (mostly w/ FF).
I also use some other telephotos, specialty lenses (macro and tilt-shift), and teleconverters.
Finally, and frankly, I think it's a mistake to buy a lens now based upon "someday... maybe" going full frame. For one, not everyone needs a full frame camera... a lot of people just think it will somehow be the best thing for them. In truth, many might be better served sticking with a crop camera. Another thing, if and when you finally do go full frame, it's pretty easy enough to sell off any "crop only" lenses you acquire. In fact, with prices going up over the past year, you could have bought several Canon EF-S lenses a few years ago, used them, then sold them for a profit now. In effect, you'd have had the use of them for free for the years in between.
There are a lot of excellent "crop only" lenses available, they can be more affordable, more compact and perhaps even a better match for your current camera. It would be a shame not to seriously consider them.
rick_reno
Nov 09, 2011 14:50 |  #10
15-85 is a nice lens on a crop body
Sirrith
Gallery: 50 photos
Joined Nov 2010
Nov 09, 2011 15:41 |  #11
Vixen89 wrote in post #13376773 (external link)
+1
Love this little lens, worth every penny. I bought mine as an upgrade from the kit lens, because I wanted more range, faster focus, better IQ, and faster aperture. This lens has it all, whereas usually you have to settle for some only.
-Tom
pixelPeteK
Joined Nov 2010
Nov 09, 2011 15:53 as a reply to  @ Sirrith's post |  #12
Great read. I just picked up a 60D with a kit lens. I planned on getting a 70-200 f/2.8L IS II. I love this site.
LemonScent
Joined Jul 2011
Nov 09, 2011 15:56 |  #13
+2! Great walkaround, general purpose lens.
Lisa
A full frame thingy, some lens thingys and a flashy thingy
L.J.G.
"Not brigth enough"
Nov 09, 2011 16:07 |  #14
I will also say 15-85 is an awesome lens on a crop sensor. As for the 50, be careful, I find mine too long indoors and also outdoors if I am close. I brought a Sigma 30 f1.4 and find it a lot handier than the 50 f1.4. In fact I have not used the 50 since buying the 30.
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
p32shooter
Nov 09, 2011 18:29 |  #15
i use a 17-55 f2.8 on 1 40d for walkaround
the 30mm f1.4 sigma mimics the 50mm on 35mm film body so it gets used too
both the 50mm f1.8/1.4 and the 85mm f1.8 are really short teles on the crop bodies
before the 15-85 there was a 17-85 that resides on a rebel xti i use sometimes
ymmv
wants for Ls :D , now have 400do;500f4is,600f4 :cool::cool: off to birding and airshows:):):)
4,044 views & 0 likes for this thread, 17 members have posted to it.
Latest registered member is vinceisvisual
940 guests, 175 members online
