Thread started 13 Nov 2011 (Sunday) 11:45
Statue - Before and After
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Nov 13, 2011 11:45 |  #1
This was taken somewhere in Paris. (If anyone recognizes it, let me know). I usually don't photograph someone else's art, but the intention was a vacation memory. I always hated the background, and worked on several ways to improve it (straigtening, mild desat, etc).
Finally, I took it all the way down to black and liked that. Then I bumped the saturation and added some noise. High pass filter for texture, and finally got a presentation I like.
Any thoughts?
Rad
5DII
1/40
f/4.5
iso 6400
50mm (Canon 28-135)
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
whoty
Gallery: 20 photos
Joined Nov 2010
Nov 13, 2011 15:29 |  #2
2 things would make this picture better. Fix the tilt,it's leaning left a lil and get rid of the background completely.
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams
Instagram (external link)
Facebook (external link)
NewEnglandPhotographer
Nov 13, 2011 15:45 |  #3
pretty awful.
You took somebody else's art and messed with it.
Why would you want to add noise? lol
neither photo do anything for me. The first would be categorized as a "P&S vacation-memory shot"..
Canon 7D | 70-200mm f2.8is II L | 24-70mm f2.8 L | 50mm f1.8 | 28mm f1.8 | Canon 1.4x TC II | 580EX II
whoty
Gallery: 20 photos
Joined Nov 2010
Nov 13, 2011 15:56 |  #4
Something like this,maybe BW?
proximustherogue
Joined May 2011
Nov 13, 2011 17:02 |  #5
a bit of selective adjustments would be in order I think.
Instead of doing the entire picture perhaps just changing the color of the statue and the mount.
then make the background completly black as in the BW version you posted.
get out and shoot
neil_r
Cream of the Proverbial Crop
Joined Jan 2003
Nov 13, 2011 17:05 |  #6
So you went somewhere, took a picture and you don't know where it is? You might want to add a notebook to you gear list.
Neil - © NHR Photography
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Nov 13, 2011 17:08 |  #7
In any sort of conversion, I doubt you want to lose detail where you had it before. For example, the hair on the back of the first figure's head. In the conversion, it's entirely black and blended into the background. For this reason, it doesn't work for me.
To start, you might want to do a simple levels and curves adjustment to darken the background and keep the details in midtones and highlights to your liking. What I did here was crop it slightly and also cloned the background (could have also airbrushed black) to get rid of other distracting elements.
I don't really have an artistic vision for this image, so I left it like this. I think this should be your starting point... then have at it how you see fit.
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
Sunset1971
Joined Nov 2011
Nov 13, 2011 17:18 |  #8
The tilt still seems to be a bit off. Even without the reference of the door it is noticeable. You may need to fix the tilt before removing the door frame so you can use it as a reference.
5D Mark II, 5D Classic, 17-40mm f/4.0L, 24-105mm f/4.0L, 70-200mm f/4.0L IS, 100-400mm f/4.5-5.6L, 50mm f/1.2L, 85mm f/1.2L, 300mm f/4.0L IS, 400mm f/2.8L IS, 600mm f/4.0, 800mm f/5.6L, 100mm f/2.8L
"You are braver than you believe, stronger than you seem and smarter than you think."
Nathan
Gallery: 18 photos
Nov 13, 2011 17:21 |  #9
There seems to be a tiny bit of distortion in the image that needs to be fixed. Adjusting the tilt make the doorframe aligned with gridlines throws the image further off.
Nomofica
Nov 13, 2011 22:57 |  #10
neil_r wrote in post #13394776 (external link)
Something I always beat myself up over if I've forgotten at home!
Portfolio (external link) | 5∞ (external link) | Flickr (external link)
3,182 views & 0 likes for this thread, 8 members have posted to it.
1048 guests, 105 members online
