I'm off to Iceland soon and was looking to create a long exposure followed by the flash firing at the end.
Now, with the PW TT5's you cannot use them in bulb mode. So manual is fine up to a 30 second exposure EXCEPT that for some reason the flash fires at about 8 seconds every time.
Set it for 5 secs and it works perfectly. Set it for 10 seconds or greater no dice. Tried with multiple bodies and the results are the same.
So thought I'd try the multimax triggers instead but I can't work out how to set them for 2nd curtain sync.
Can anyone help?
Thanks!
Chris
