Thread started 15 Nov 2011 (Tuesday) 14:56
Help with DPI issue
ducklabdad
Nov 15, 2011 14:56 |  #1
I have just noticed that when I downloaded some pictures from my 2 cameras 1 XSi, 1 XS that they are all downloading at 72dpi.
Cameras are set for High quality jpeg. Why would they be downloading at that low a DPI.
I am downloading into Windows Photo Gallery!!
Why would this be happening and what can I do to fix this?
Just an "ole dog" trying to learn "new tricks"! helpful advice is always welcome!!
Canon 7d, Canon XS/ XSi,18-55, 14-40 L, 70-300, and Bigmos! my"work in progress" http://ducklabdad.smug​mug.com/ (external link)
ScottGCanon
Nov 15, 2011 15:03 |  #2
What do you mean by "Downloading"? Are you taking out the Memory card from the camera, and putting in a reader on your computer to copy over?
ScottGCanon
All Canon: 1D mIV, 5D mII, 7D, 60D, 300mm f/2.8 L IS (4K)
Internet Tax Freedom Act ITFA has been renewed through Nov 11, 2014.
ScottGCanon
Nov 15, 2011 15:23 |  #3
I was just thinking about this and there are IMPORT Settings in Windows Photo Gallery that can mess with this.
1. Do one of the following:
• Connect a camera to your computer by using the camera's USB cable, and then turn on the camera.
2. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
3. To change the settings that are used when importing pictures and videos, click Import settings in the Import Pictures and Videos dialog box.
4. Change one or more settings in the Import Settings dialog box, and then click OK.
5. Click OK to restart Import Pictures and Videos. Type a tag in the Tag these pictures (optional) box, and then click Import to import your pictures and videos using the new settings.
ScottGCanon
artyman
Sleepless in Hampshire
Gallery: 17 photos
Nov 15, 2011 15:27 |  #4
The dpi in an image has no relevance to it's quality, it only applies when you choose to print it. 72 is the standard monitor dpi and has no effect on the image IQ. For example if you have an image that is say 3000x2000 if you print that at 300dpi (considered good for print quality) you would get a 10"x 6.5" print, print it at 150dpi and you get a 20" x 13". The distance a print is viewed at also affects what dpi you can get away with. Peering extremely close up will show though but who looks at prints like that! If you can see 75dpi at four feet I would be seriously impressed, so you could be looking at your prints in an impressive 40" x 27" mind you the printer will cost a bit :D
Ken
JeffreyG
Gallery: 42 photos
Nov 15, 2011 15:27 |  #5
DPI means nothing, Canon just defaults to 72. Look at how many pixels you have on each side, that sets the real dpi when you print.
ducklabdad
Nov 15, 2011 16:15 |  #6
Thanks for the response,
Yes I do mean placing the memory card in the reader and importing.
When I do as instructed I do not get an Import Settings for windows I am getting the list of systems that can be used to download that are on my computer including the Eos utility, Photoshop Elements and Windows but Windows does not give ma any selections.
ducklabdad
Nov 15, 2011 16:17 |  #7
just concerned as I was about to print some 8x10's and in the past I have always printed then at 300dpi and was just surprised to see 72 on everything!! kinda had me in a panic!!
jack880
Gallery: 13 photos
Joined Apr 2011
Nov 15, 2011 16:32 |  #8
If the image is 4272 pixels wide, printing at 10" wide will give you a theoretical printed resolution of 427 dpi, so if the printer prints a lower dpi than that it's the printer not the camera that's limiting the resolution...
Someone correct me if I'm wrong (as if I need to ask).....
https://www.flickr.com​/photos/jackhenriques/ (external link)
1DX, 7D, 20D, G7X II, 70-200 f/2.8 L IS II, 24-70 f/2.8 L, 16-35 f/2.8 L II, 50 f/1.8 II, 50 f/1.4, TS-E 17 f/4 L, 8-15 f/4 L, Sigma 17-50 f/2.8, Sigma 8-16 f/4.5-5.6, Sigma 150 f/2.8 macro, x1.4 extender II, Kenko extension tubes, 430 EX II x 2, DJI Mavic Air
Jim_T
Joined Nov 2003
Nov 15, 2011 16:42 |  #9
DPI stands for dots per inch.... The dots are the pixels in the image and the inches are real world physical inches.
DPI is obtained by dividing the pixels by the inches. That's all there is to it.
What confuses most people about DPI is that they don't realize it's about inches and pixels and it's not some hypothetical figure of merit.
Next time you open an image in your favorite editor and call up the image size window.. look at the Pixels and the Inches as well as the DPI.. You'll see that the reported DPI will ALWAYS be the pixels divided by the inches. It's mathematically impossible for DPI to be anything else.
tzalman
Fatal attraction.
Nov 15, 2011 16:58 |  #10
As said above, the i in dpi stands for inches. You only have inches when you have a print. Did the camera designer know what size print you will make? Of course not. So the final dpi is unknown. But the EXIF standard requires that the field be filled and that if the actual dpi is unknown the value entered be 72 (for outmoded historical reasons). So Canon writes 72 there. Other makers realize that 72 doesn't sound very impressive and write bigger numbers, but whatever the number is, it is arbitrary and irrelevant.
Elie / אלי
959 views & 0 likes for this thread
Help with DPI issue
Latest registered member is elkaboing
851 guests, 192 members online
