Is there any risk associated with using high speed synch repeatedly in a short amount of time?
RiONhimself Member 88 posts Joined Jul 2011 More info | Nov 16, 2011 21:07 | #1 Is there any risk associated with using high speed synch repeatedly in a short amount of time?
klr.b Goldmember 2,509 posts Joined Jun 2009 Location: SoCal More info | Nov 16, 2011 22:39 | #2 RiONhimself wrote in post #13410816 Is there any risk associated with using high speed synch repeatedly in a short amount of time? Is there a reason you type like this? gordon
JohnSchell Senior Member More info | Nov 16, 2011 22:46 | #3 |
Nov 16, 2011 23:56 | #4 John Schell wrote in post #13411291 Seems like you should be figuring this out yourself. Joh Schell - Its a reference to a thought that suggests the world you live in is entirely a figment of your imagination.
HiggsBoson Goldmember 1,958 posts Likes: 4 Joined Jan 2011 Location: Texas Hill Country More info | Nov 17, 2011 00:02 | #5 RiONhimself wrote in post #13411552 Its a reference to a thought that suggests the world you live in is entirely a figment of your imagination. Then accordingly, any future troubles are only in your mind. A9 | 25 | 55 | 85 | 90 | 135
RalphIII Goldmember 1,352 posts Likes: 16 Joined Mar 2009 Location: Alabama More info | Nov 17, 2011 00:23 | #6 RiONhimself wrote in post #13411552 Its a reference to a thought that suggests the world you live in is entirely a figment of your imagination. When I was in sixth grade, a few decades ago, our teacher asked, "how do you know all this isn't a dream?", in challenging us. "SOUTHERN and SAVED!"
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Nov 17, 2011 01:11 | #7 The danger of overuse of HSS is the same as the danger of overuse of any flash mode...thermal overload, which will cause a 580EXII to protect itself by slowing down the recycle rate so that the flash can cool. (The older 580EX will merely burn itself out...the newer 580EXII is more idiot proofed against thermal abuse causing burn out.) You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is ealarcon 1036 guests, 170 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
