Thread started 08 Nov 2005 (Tuesday) 06:48
New Tamron 28-75
quadphoto
Nov 08, 2005 06:48 |  #1
After a lot of research on this forum i decided to buy the Tamron 28-75 for my 20D, I used it over the weekend out doors in very poor light and the results were not that good, so i decided to do a focus test today and i think it may be slightly front focusing. Is front or back focusing caused by the Camera Body focusing mechanism or the Lens?
any advise please, Quadphoto.
Tamron 28-75 8mm@f2.8 (INVALID EMAIL)
dhbailey
Joined Oct 2004
Nov 08, 2005 06:57 |  #2
You have to remember that the red square in the viewfinder is slightly smaller than the actual AF point that the camera use (why this is so, only Canon could enlighten us about). So you might try the same test again with the red square slightly higher than you think it ought to be, to see if the picture is focused then where you think it ought to be. That "focus here" line is fairly thick, so there are lots of potential combinations of alignment which would be within human error margins, such as the top of your red square in the middle of the text.
I'm not sure if Canon or Tamron would look on this as front-focusing or as being within the acceptable margin of error.
David
Cameras: S3is and 20D
Canon 18-55 kit lens, 50mm 1.8, 75-300 USM IS
Tamron 28-75 F2.8, 420EX flash
Tomasz ­ Dziechciarz
Joined Jan 2005
Nov 08, 2005 07:34 |  #3
Can You send me copy of this chart to test my 28-75, please?
It can be pdf file or any other ..
poczta@dziechciarz.art​.pl (external link)
Many thanks
Tomasz
www.dziechciarz.art.pl (external link), www.pbase.com/tomaszd (external link),
5D,3 +grip, 20D+grip,17-40L, 24-105/4L, 70-200L, EF- Primes 35/1,4;50/1,4;85/1,8;1​35/2, 580EX,580EX ll, ST-T2, KENKO TC 1,4 and KENKO ext tubes,TAMRAC Pro 5 & Turbo Cyber Pro bag & Compu Rover AW
quadphoto
Nov 08, 2005 07:41 |  #4
Tomasz here is the link where you can down load the test chart and instructions.
http://md.co.za/d70/ch​art.html (external link)
mdm
Nov 08, 2005 11:51 |  #5
I'm going to test mine too. Thanks
kawter2
Joined Aug 2004
Nov 08, 2005 11:53 |  #6
seems to me like you are splitting hairs..
@ 2.8 as close as you were.. think you have a keeper
Wedding Blog (external link)
Eric J. Weddings (external link)
Tsmith
Formerly known as Bluedog_XT
Nov 08, 2005 12:07 as a reply to  @ kawter2's post |  #7
It could be the angle you were using. That to me doesn't look quiet at 45 degrees. Here's my result done when acquiring my copy:
70mm @ f/2.8
70mm @ f/4
condyk
Africa's #1 Tour Guide
Nov 08, 2005 12:18 |  #8
quadphoto wrote:
... I used it over the weekend out doors in very poor light and the results were not that good
Gawd some of you guys are fussy. Test charge is fine as far as I'm concerned. More likely the conditions caused any problems in real world shooting.
https://photography-on-the.net …/showthread.php​?t=1203740
tim
Light Bringer
Nov 08, 2005 17:26 |  #9
Looks like a slight front focus to me, but i'd probably stay with it. Shoot the test chart 5 times, focus on infinity between shots, make sure you use a tripod.
m3incorp
Nov 09, 2005 02:52 |  #10
Initially I was thinking mine was a tad soft at f/2.8, still may be and Tamron will calibrate if necessary if I don't mind being without for a month. Then got to thinking, just how often do I shoot at f/2.8 with that particuliar lens. That coupled with the fact that others say it looks great, will probably sway me to leaving well enough alone. If not pixel peeking, then I am sure the lens is sharp all the way.
7D, 10D, Canon EFS 18-55mm modded
Canon EF 50mm, Canon 85mm 1.8, Tamron 17-50mm F/2.8 XR DiII VC
Canon EF 70-300mm, 70-200 F4 L
, Canon 430ex ii Speedlite.
Tsmith
Nov 09, 2005 07:00 as a reply to  @ m3incorp's post |  #11
m3incorp wrote:
Initially I was thinking mine was a tad soft at f/2.8, still may be and Tamron will calibrate if necessary if I don't mind being without for a month. Then got to thinking, just how often do I shoot at f/2.8 with that particular lens. That coupled with the fact that others say it looks great, will probably sway me to leaving well enough alone. If not pixel peeking, then I am sure the lens is sharp all the way.
I tend to lean toward user error sometimes with mine @ f/2.8 as well. I've gotten some outstanding results but also have seen a few softer ones too. Not enough to warrant sending it off.
StealthLude
Dec 24, 2005 04:36 |  #12
Ya same here,.. I use mine and SOME shots at 2.8 are sharp, some are soft.... ?
It may be the distance away from the object... Its not very sharp at 2.8 when im shooting distance, sometimes ever portrait.
[[Gear List]]
Skype: Stealthlude
Simon ­ Spiers
Joined Jan 2005
Location: Crawley Down West Sussex UK (SE of Gatwick Airport)
Dec 24, 2005 11:13 |  #13
IF YOU WANT TO ENJOY THIS LENS, DONT WIND YOURSELVES UP OVER THIS TEST.
I will not be testing mine as i am pleased with the results. If i find a slight front or back focus error, then it will grind at me. Go out and enjoy the lens, if it looks poor when you get the results home then do the test.
Canon EOS 20D /70D/450D/ Tamron SP AF 17-35 mm f 2.8-4 DI/Tamron
28-75mm f2.8 XR DI / Canon EF 100-400 USM IS L / Speedlite 580EX and Better Beamer/ Pentax SMC Takumar 50mm f1.4
quadphoto
Dec 24, 2005 13:36 |  #14
Simon, when i originally posted this thread i was seeking advice concerning the front focusing problem that my new Tamron 28-75 lens was suffering from, and i very much doubt that this test would WIND anyone up that was about to buy or had just bought this lens. I took loads of images before doing this focus test because the front focusing problem existed as far as f5.6 there was clearly problem with this lens and you did not have to be a photographic expert to realise it. When I contacted Tamron UK they openly admitted that there was a focusing issue with the Canon fit 28-75 F2.8 XR Di lens, and they had successfully re-calibrated all the ones returned to them, I returned mine and it now focuses accurate and is pin sharp and i am enjoying it very much, good luck with yours.
markyb
Dec 24, 2005 14:21 as a reply to  @ quadphoto's post |  #15
seen lots of posts about front / back focusing
could somebody explain (in plain english) what this is all about please
Canon EOS 30 D EOS 350 D canon eos 5d mk1, 100-400 L / 24-70 L / 70-200 ,canon eos 17-40 LL F4 / 10-22 /50 1.8, Sigma 105mm 2.8
http://markbarnes.foto​pic.net/list_collectio​ns.php (external link)
2,162 views & 0 likes for this thread, 12 members have posted to it.
New Tamron 28-75
1779 guests, 133 members online
