Thread started 08 Nov 2005 (Tuesday) 11:54
canon 580ex and pocket wizard
sam0329
Nov 08, 2005 11:54 |  #1
HI EVERYONE
I have 2 580Ex and I do kown that I can use the canon wireless. However, the distance is not very good for a open space or church. I m going to purchase the Pocket Wizard Plus, my question is: do I need 1 Transmitter + 1 Reciever, or 1 Trans + 2 reciever since I have 2 Canon 580EX, please advice, thx.
wannasmaxx
Nov 08, 2005 12:18 |  #2
You'd nee 2 receivers.
20D, BG-E2, 24-70/2.8L, 70-200/2.8LIS, 430EX
mgbeach
Nov 08, 2005 12:18 |  #3
can you not slave one 580 off the other in a situation like this?
Michael G. Beach
Canon EOS 30D
EF 24-105mm f/4 L IS; EF 70-200 f/4 L; EF 100 Macro f/2.8
430EX, Alien Bees B800, Vagabond battery
http://www.flickr.com/​photos/michaelbeach (external link)
sam0329
Nov 08, 2005 12:45 as a reply to  @ wannasmaxx's post |  #4
So I guess I cannot trigger one 580EX as master and other one as slave rite? Thx
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
Nov 08, 2005 13:16 |  #5
What's the range for wireless-ttl anyway? I'm assuming 15-20ft. wouldn't be a problem.
Mac users swear by their computers. PC users swear at theirs.
sam0329
Nov 08, 2005 13:19 as a reply to  @ Ronald S. Jr.'s post |  #6
Thats right, however, the slave unit is not working sometimes, thats the problem... I did have my slave receiver facing the master, somehow it still randomly not working... said :confused:
beardo
Nov 08, 2005 20:08 |  #7
I'm not sure on this but you might be able to have one flash on your camera hot shoe and the pocket wizard transmitter plugged into the cameras pc terminal (if it has one). Both flashes would need to be set to manual I assume.
Canon 10d, 15mm fishey, 24-85 usm, 100-300usm 50mm f 1.8 580ex, 550ex, 420ex
sam0329
Nov 09, 2005 09:26 |  #8
So I heard I need to buy the adaptor and cable in order to with Canon flash, can someone kindly tell me what I need to make my 2 580EX work with the receiver? Thx
gmen
Joined Aug 2004
Nov 09, 2005 11:25 |  #9
A possible configuration is:
Pocket Wizard Transmitter in the camera hot shoe
One 580EX connected to Pocket Wizard Receiver with one of these (external link)
Second 580EX triggered using one of these (external link) (used as an optical slave) or maybe even one of these (external link) (as long as the metal base doesn't cause a problem with the pins on the 580EX shoe)
You'll most likely need a flash meter as well, as this would be an all-manual system.
I have not tested this system - if this concept is flawed in any way, I am sure someone else will tell us why ;)
---- Gavin
TGSPhoto Editorial Sports Photography (external link) | TGS Blog (external link) | TGS Twitter (external link) | TGS Sportsshooter (external link) | TGS Tweets (external link) | TGS Facebook (external link) | LinkedIn (external link)
sam0329
Nov 09, 2005 12:43 |  #10
So I guess the best and safe way is 1 Transmitter and 2 receiver, ph and a light meter rite? what about the Sekonic L-558 Dual Master or the 368, please adive and thanks again.
gmen
Joined Aug 2004
Nov 09, 2005 13:28 |  #11
Yep two PW receivers and two of the Paramount Cords is going to be the best solution. Remember you can also use the PWs to trigger cameras as well - so you can set up a nifty remote camera if you ever feel that way inclined!
The Sekonic L358 should be just fine as a meter - there are numerous threads on it if you do a quick search on the forum.
Good luck.
---- Gavin
3,370 views & 0 likes for this thread, 6 members have posted to it.
658 guests, 120 members online
