Thread started 08 Nov 2005 (Tuesday) 13:21
Outdoors Fill Flash - Sto-fen or Bare Flash?
GovtLawyer
Nov 08, 2005 13:21 |  #1
Indoors, I use a bare flash bounce (when possible) and a white card. Works well for me. Outdoors, as a daylight fill-flash, I usually use a direct bare flash fill, and occassionally use a FEC setting. I have seen numerous professional photographers use the sto-fen omni bounce (or one quite similar) for direct, non-bounce outdoors shots. Some, have even angled them upward, which seems weird to me, as there is nothing to bounce off.
So, is there any advantage to using a sto-fen omni-bounce for outdoors fill flash?
etaf
Nov 08, 2005 13:54 |  #2
i use a sto-fen for all my outside fill flash.
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
subtle_spectre
Nov 08, 2005 14:20 |  #3
I use a Lumiquest Ultrasoft...
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
tim
Light Bringer
Nov 08, 2005 14:51 |  #4
Try it and decide for yourself, that's the best way with most photography things.
The Omnibounce is for bouncing, I use naked flash outside.
mgbeach
Nov 08, 2005 15:44 |  #5
In regards to angling the flash outdoors, it's often quicker to point it up quickly to reduce effective output than it is to go in and change FEC back and forth. I leave the Omnibounce on all the time, even for outdoor portraiture. It seems to soften the light a bit to me, reducing extreme highlights on the bridge of the nose, etc.
Michael G. Beach
Canon EOS 30D
EF 24-105mm f/4 L IS; EF 70-200 f/4 L; EF 100 Macro f/2.8
430EX, Alien Bees B800, Vagabond battery
http://www.flickr.com/​photos/michaelbeach (external link)
GovtLawyer
Nov 08, 2005 16:41 as a reply to  @ tim's post |  #6
Of course, I'd have to buy it first. That's why I came here and asked all of you experts.
tim
Light Bringer
Nov 08, 2005 16:57 |  #7
Good call. Don't bother IMHO.
Wavy ­ C
Joined Jan 2005
Nov 08, 2005 21:31 |  #8
I've tried outdoor fill flash both with and without the ommibounce and can't say I've noticed a lot of difference. It works best indoors.
The ommibounce also soaks up quite a bit of light, so your flash will likely take longer to recycle if that's important to you.
It wasn't me!
dsze
Joined May 2004
Nov 08, 2005 21:32 |  #9
I leave my diffusers on all the time as well, except for my slave which often is bare. The stoffen is supposed to be angled up in most situations, mine almost always is...even outdoors.
-daniel
"Life is not measured by the number of breaths we take, but by the moments that take our breath away."
-Gear List-
AMG
Nov 09, 2005 07:50 |  #10
why should the the stofen be angled upwards outdoors, what will this do ?
Adobe certified
Rebel XT
Canon 28-105 3.5-4.5; canon 50mm 1.8; canon 18-200mm IS; Speed light 420 EX
akiwi
Joined Jun 2005
Nov 09, 2005 07:54 |  #11
For outdoors probably a mini soft box is best. Depends a bit on how far you are from your subject. I have one, but haven't tried it outdoors.
Peter
www.PeterHansenPhoto.d​e (external link)
Gear:: Canon 7D & 350D :: EF 24-70 F2.8L :: EF-s 17-85:: 50mm 1.8 ::70-200 F4L ::100 F2.8 Macro:: Sigma 10-20 :: 580EX:: Elinchrom studio lights:: loads of other bibs & bobs.
GovtLawyer
Nov 09, 2005 17:08 as a reply to  @ AMG's post |  #12
I haven't seen a logical explanation for this in any thread yet. The only thing I've read about the Sto-Fen outdoors, is that straight on, it would soften the light a bit, such as keeping hot spots off a face or bald dome. Makes sense to me, but doesn't seem all that worthwhile.
dsze
Joined May 2004
Nov 09, 2005 17:12 as a reply to  @ AMG's post |  #13
The little piece of paper that comes with the Sto-fen (the one that no one reads) says specifically that it should not be used straight on, but always at a 45 degree angle. I would guess that is has to do with the way the light is released from the sto-fen... I would guess that it doesn't come out of the front (straight on) very well, but rather around the edges. Can anyone else offer a better explanation? I'm just guessing here as to the why, but I do like the results better with a 60 degree angle most of the time.
-daniel
-Gear List-
tim
Light Bringer
Nov 09, 2005 17:31 |  #14
Try it and see. I used the stofen straight on once, the person in the photo came out strangely orange, whereas at 45 degrees it was fine.
It's called an omnibounce for a reason... use it when you bounce, otherwise use direct flash IMHO.
dsze
Joined May 2004
Nov 09, 2005 17:34 |  #15
Yes, I agree with Tim about the strangeness straight on with the sto-fen... however, I think it bounces inside the plastic. I dont' think it should only be used when you bounce off a wall, ceiling or reflector. The light bounces inside and comes out of the sides in a softened fashion... I'm totally guessing though, I could be way off.
-daniel
-Gear List-
21,082 views & 0 likes for this thread, 19 members have posted to it.
2719 guests, 153 members online
