Thread started 21 Nov 2011 (Monday) 11:32
Elph 300HS (Ixus 220 HS) lines in video
Pixels
Joined Jul 2003
Nov 21, 2011 11:32 |  #1
Just got new Elph 300 HS (a.k.a. Ixus 220 HS in Europe) - and have taken some test shots in 1080P video, highest resolution setting.
I note that when shooting in flourescent lighting, I get horizontal lines moving up frame.. and am wondering if this is normal or is there some fault with the camera? Current here (Ireland) is AC 220/240 50 cycles.
Shots taken in daylight haven't got this problem.
Would welcome any opinions/comments.
Also I note that shots panned horizontally in daylight are a bit jerky, i.e. not smooth.
Am thinking of returning the unit.
Canon 24-105 L IS USM,
Canon 400mm L f5.6
Canon 7D, Canon 1.4 TCII
Canon 10-22, Canon 420EX speedlite,
Olympus OMD EM5, 20-40 f2.8 PRO
Jon
Joined Jun 2004
Nov 21, 2011 12:31 |  #2
What you're seeing is the flickering of the fluorescent lights being captured by the video.
As for the jerky pans - if you have IS active, it'll fight against your panning. (It's trying to damp out the motion you're introducing while panning.) If you go into the Camera menu, one of the IS settings is "Panning" - enable that and try again.
Jon
Cocker Spaniels
Pixels
Joined Jul 2003
Nov 21, 2011 14:01 as a reply to  @ Jon's post |  #3
Many thanks Jon for your reply.
Changing the the IS function to "panning" so it only corrects vertical movement has solved the "jerky" problem.
Re the horizontal lines, I accept that these are caused by to the flickering of the flourescent lighting. However this poses another question - why does my other camera - a Panasonic - not produce similar lines in movie mode under the same lighting. (It is set to AVCHD lite - 720 p)?
edit - I note that the lines are not there on the Elph when the video mode is set at the lower 12890 setting.
Canon 400mm L f5.6
tkbslc
Nov 21, 2011 14:53 as a reply to  @ Pixels's post |  #4
It most likely has to do with the frame rates matching the cycle of the lighting. In 50hz countries, the cameras should be capable of 25 or 50fps, and that should help. My guess is your other camera is set on 25 or 50 and the Canon is on 30 or 60fps (which is the default for US and Japan). If you can look at the video settings and see if you can set it to 25 fps, the problem should go away.
Edit: looking at the specs, the camera might not have 25 or 50fps options. 1920x1080 @ 24 would be the next best option as 24 is close enough to 25
Taylor
EOS Rp | iPhone 11 Pro Max
Pixels
Joined Jul 2003
Nov 21, 2011 15:15 |  #5
tkbslc wrote in post #13431737 (external link)
Thanks tkbsic for your response.
The HD video specs for the Elph 300 include 2 settings: 1920 x 1080 24 fps, and 1280 x 720 30 fps.
The 720 30 fps lower spec doesn't have the lines problem, but the higher 1080 30 fps does!
I have checked the other camera (Panasonic) and it has 1280 x 720 30 fps as its highest setting.
So to get around the problem it looks like I will have to select the lower HD setting when shooting in flourescent light, and use the higher for daytime.
Canon 400mm L f5.6
tkbslc
Nov 21, 2011 15:23 |  #6
Pixels wrote in post #13431846 (external link)
That's very odd. I would have expected the opposite. I guess keep experimenting! :)
Taylor
Pixels
Joined Jul 2003
Nov 21, 2011 15:32 |  #7
tkbslc wrote in post #13431893 (external link)
Correction of error: I meant to say that the higher 1920 x 1080 24 fps setting displays the problem. Sorry.
Canon 400mm L f5.6
imjason
Joined Nov 2010
Nov 21, 2011 16:41 |  #8
Pixels wrote in post #13431516 (external link)
is your panasonic a CCD? what youre seeing right now is a characteristic of a CMOS sensor when youre around older slower cycling fluorescent light.
Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
Pixels
Joined Jul 2003
Nov 21, 2011 17:34 |  #9
imjason wrote in post #13432244 (external link)
Yes the Panasonic is a CCD sensor, whereas the Canon is CMOS.
Canon 400mm L f5.6
2,820 views & 0 likes for this thread, 4 members have posted to it.
1550 guests, 134 members online
